Question about Acer Aspire 5500 5570-2609 Laptop
Acer won't power on and supply is good. can you help me
  • dewey wyatt May 11, 2010
    how do you know the powersupply is good, have you load tested it? if the battery is removed the ps should run it unless you have another problem inside the laptop.if that is the case then you will have to take it for repairs. usually the boars are replaced inside.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Have you tried taking out the battery and just using the adapter.
Monitor disply disturbe me
Posted on Aug 23, 2009
Acer ax1301 won't power on
It's very possible that when your power supply died so did your motherboard. Especially if a power surge was involved..
Aug 18, 2012 | Acer America Acer Aspire AX1301-U9032...
Ive recently started to use my acer aspire one laptop and it won't charge and the charge light keeps blinking and once it hits the windows screen it turns off
Take it to a best buy or staples, ask them to hook the laptop up to a universal power supply to see if that is your problem.
if so... then you can buy a replacement power supply while you are there
Jul 28, 2012 | Acer Aspire One PC Notebook
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
I have a acer aspire 6930. it won't turn on.
If it is a destop, the normal problem is the CPU power supply and it might be damaged because of certain cases like power surge and others.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
May 12, 2011 | Acer Computers & Internet
Acer monitor won`t turn on
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 24, 2010 | Acer 22" X223w LCD Monitor
Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Mar 05, 2010 | Acer Extensa 5630-6806 Notebook
Please HELP!! I have a Acer Aspire Laptop
Hello, so does the computer turn on without ac power, if it does it is a good indication that you may have a problem with the power supply or power connector in the computer.
Sep 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
Acer Aspire 5500 5570-2609 Laptop Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
