Question about Maytag Dryers
30amp trip after getting hot
I have a maytag performa when it run so long the breaker get hot and it kicks the breaker off, i have a 30amp breaker should it be a 40amp. It jus started doing this after 4 month. are could the breaker be bad.
  • Maytag Master
  • 1,236 Answers
Look on the unit for the electrical data plate. It should have the required amperage rating on it.
Have the actual amperage being pulled by the unit checked.
You may have improper voltage being supplied to the unit which causes excessive amperage.
The breaker could be weak. Meaning that it may be tripping at an amperage less than 30.
Your wire size may be too small for the circuit which would cause overheating of the circuit and tripping the breaker.
Do not change the breaker to a higher amperage unless the wire size attached to that circuit is rated for it.
A breakers job is to stop power should a overheating of circuit or a short circuit occurs. It protects the circuit from catching fire inside the walls and burning the place down.
Good Luck and I hope this helps.
Posted on Mar 08, 2009
Keeps tripping breaker on 30amp service
Sounds like you may have a weak breaker or under size conductors. For 30A you need at least 10 awg conductor. Did this help?
Oct 22, 2013 | Electrical Supplies
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
My dryer will run but will not get hot. The trouble shooting guide says that on of the two house fuses in the circuit may be blown or the thermal limiter is tripped. Where are the fuses in the dryer. I...
First id make sure you have both phase of AC power coming into dryer.
Go to your house panel and reset yoru house breaker for the dryer. If in the USA the breaker should be a 240volt / 30amp breaker. It will have two breakers tied together at the trip switch.
If AC power is good at the dryer outlet then it could be one of the followings.
  1. Open Thermal limit fuse or trip switch.
  2. Open Heater Element.
  3. Control board is faulty.
Oct 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Maytag Performa washer will not drain?
i'd look at replacing the motor that sounds like the prob
Jun 11, 2009 | Maytag Performa PAV2200
30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Mar 05, 2009 | Weather King 10AJA2501AH Air Conditioner
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Maytag performa dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't come on
motor relay on control board, thermal fuse or breakers are tripped, check breakers 1st
Dec 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Mar 18, 2008 | Maytag SDE5401AYW Electric Dryer
Dryers Logo
117 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
