Question about GE 24 in. GLD6560LSS Stainless Steel Free-Standing Dishwasher
Dishwasher displays 888 on LCD and Cycles through settings on own
GE GLD6560LOOSS Dishwasher (only 3 years old) Worked great up until yesterday. The Start/Reset button was blinking, I loaded the dishwasher, put the detergent in and Pressed Start. It didn't start so I pressed it again, nothing happened so I held the button down thinking that was how to use the Reset. All the lights lit up quickly and the display reads 888 (which I read is some sort of display that shows with loss of power). When I close the door the dishwasher starts, but runs a cycle on it's own for about 5 minutes or so and then it switches to another cycle and runs that for a few minutes then switches to another and so on. The status lights aren't lighting up during this process, but the dishwasher is getting hot, running the water and such like it should be only it never progresses past the first few minutes so the detergent dispenser never opens. If I open the dishwasher it's steaming hot and everything is wet so I know it's at least operating, just not properly. I was hoping to find some sort of power reset button or tripping the breaker off and then back...no luck with that. I pulled the panel off and the toe kick panel, but didn't really know what to look for so I put it back together. When I close the door it's really weird it will start running immediately like it's in the middle of a cycle. It will go from say ''Pots/Pans'' and ''China/Crystal'' (lit at the same time mind you) and run that for a few minutes. Then it switches to ''Normal'' and say ''Express Wash'' for a few minutes, Then some other combo and so on. Never doing any of the settings for long. Is there any way to reset the panel, or stop the dishwasher from what it's currently doing? I've left the door cracked which is the only immediate fix to keep it from doing anything on it's own. Thanks for any help you can send my way. I'll keep searching forums and help pages in the meantime.
  • 87 Answers
SOURCE: Wash Motor Keeps running after water pumps out
You have a bad control board in the unit.
Posted on Jun 08, 2007
  • 87 Answers
SOURCE: GE Profile dishwasher LEDs do not light up.
You have a bad control pc board.
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
yalmer
  • 552 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
  • 276 Answers
SOURCE: dishwasher cycles but does not clean the dishes
if your dishwasher is cleaning poorly, check these: Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Jul 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
GE 24 in. GLD6560LSS Stainless Steel Free-Standing Dishwasher Logo
118 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
