Question about IBM ThinkPad T30 2366 Notebook
T30 boot problem
Seems to be a common problem.
My trouble started when I installed too much RAM (2x1G). Most probable needed too much energy and fried the mother board. At least this I was thinking. No boot, nothing, just CPU fan working. But no power for CPU, airflow did not get warmer.
Ordered new mother board. After assembly no change - no boot, just CPU fan. When I lifted my computer holding it from lower left corner it suddenly reacted and booted. Everything seemed to be OK, WinXP was running smoothly (with 1G RAM). But after restart everything repeated and only slight bend of the left corner did the job.
Then I left it to hibernate and it never recovered. Tried everything (cleaned and assembled 3x, tried different power options etc.) Next thing I will try is to clean the main power switch (now it has a bad connection). But it has serious power isuues, most probably some fuses are out.
  • robinch34 Mar 11, 2009
    I have found the memory sockets to be the cause...check them for poor contact...good luck
  • 41 Answers
Once again , bad ram will prevent your computer from booting , make sure you are using a known good ram module.
don001996
Posted on Jul 19, 2009
My ibm t30 has no power even with the batterry or ac no beeps execpt the light indicates a ac has been connected
Try resetting the RAM module, it may not be making proper connection.
Remove the RAM module and connect it again.
If the laptop still does not boot up, the RAM module may be faulty, remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM module for you.
Jul 07, 2011 | IBM ThinkPad T30 2366 Notebook
It looks like common problem: my OLD T30 can see only one 256mB memory slot. Does it make sense to install one 512 mB unit? Can T30 recognize 1gB memory? Thank you in advance
Hello
Yes, you system will support up to 1GB of ram, so, if i were you i would suggest that you buy a 1GB chip, this will give you the best performance upgrade. And, ram is so cheap at the moment, so, i think it will be the best option.
Let me know if you found this helpful.
Kind regards
Andrea
Sep 09, 2010 | IBM ThinkPad T30 2366 Notebook
Dead T30 ?
Check to see if RAM modules are installed in the ThinkPad.
Check to see it the ThinkPad has a hard disk.
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 wont boot up
You have faulty RAM modules. Reseat your RAM modules, to make sure they make proper connection. If this doesn't work take them to your friendly computer shop and ask them to test them for you.
Apr 29, 2009 | Lenovo ThinkPad R51
My ibm t30 will work with it 256mb ram all the time, but the 1gb ram only works some of the time.
It seems 1 gb ram you have tried to install is not compatiable with this ibm t30. I will advice you to check the type and frequeny of 1gb ram you bought it will be written like DDR 400MHZ OR pc2 533/667 MHZ please check these two things and it should be matching with the original 256 ram which was working.
Apr 12, 2009 | Computers & Internet
T30 boots but stop , in windows inst.
I have a ibm 2373 that will only start up and show the ibm and windows xp logo briefly,then the screen goes blank,but i can hear the fan running.
Oct 01, 2008 | IBM ThinkPad T30 2366 Notebook
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Restarting PC
your motherboard may be experiencing compatibility issues with that memory youve jst installed. it will work for some time but when it starts to become unstable, it will restart, you have yo adjust the memory timings for that memory in BIOS.
Mar 18, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
T30 boot problem
Sorry, but probably your T30 (my favorite Thinkpad) has developed a problem with one of it's memory slots. It is an inherent problem with the Thinkpads. The way to tell is topress on the memory cover in a way that pushes the memory (or more to the point, the memory slots) into the motherboard. While keeping pressure on the memory, try to boot up. I use a T30, and have worked on several others, all have at least one slot with this problem. Also try taking out the memory which is closest to the front of the system, and pushing in on the remaining one. Hope this helps. If this is the problem, there are a couple of things you can do to keep it running, but probably with only one ram stick. Goood luck
Oct 07, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
217 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
