Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice maker has stoped making ice. The bar that cuts it off when enough ice is made moves a little while in the up position.
  • 360 Answers
Lifting the bar to the full up position is how you stop the ice maker from making ice. move the bar back down and ice making will resume.
Posted on Mar 08, 2009
Doesn bring water to ice maker
If you have water at the door, the most likely problem is that the metal bar that shuts the ice maker off has been moved to the off position. Check to see if the metal bar is in the up or down position. If it is up, move it down and vice versa and give it an hour to see if it begins making ice again.
May 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
Apr 14, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker jammed. Ejector fingers in incorrect position.
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
LG Refrigerator LFX24971ST - ice naker does not make ice
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
Nov 12, 2017 | LG LFX25971ST Bottom Freezer French Door...
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
The icemaker won't make ice.
Try this,Open the freezer and look at the ice maker,there is a bar above the ice bin that kinda looks like a piece of metal coat hanger,Push it to the down position.If it is already down,Post back
Please take time to rate this fixya
May 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Apr 29, 2007 | GE Profile PSS26NGS Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
143 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
