Question about Dell Dimension 4500 PC Desktop
Unable to reconnect hard drive.
Getting no hard drive detected message when trying to reinstall hard drive on dell dimension 4500 desktop appr 8 years old. Is the hard drive bad or just connected wrong?
  • 53 Answers
Check  for the connection first try two r three combinations and still if u dont get it then the hard drive is fault
Posted on Mar 08, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Error message: Pri Slave Hard disk A S.M.A.R.T. ERROR has ben detected
Your hard disk might be dead due to sudden power cut or may be a shock on the hard disk while it was working due to an accidental hit on the c.p.u. You can give it to a computer mechanic to test the drive if its working or not. If not then you may check its warranty period and if its over you have no other option than replacing it. I also had the same problem with my hard disk.
Oct 14, 2011 | Dell Dimension 4500 PC Desktop
I have a reformatted hard drive in a Dell dimension 43000. Now on turning on I get NTLDR is missing message. If I use F2 or F12 to try & correct the set up the USB keyboard stops working so I am then...
Reinstall the Operating system (Windows). Missing file is from there. Many computers don't switch on USB when in BIOS - borrow a keyboard with a standard PS/2 plug on it, but the USB will be fine once the Operating System is reinstalled.
Oct 27, 2009 | Dell Dimension 4600 PC Desktop
Missing Windows XP Product Key-Need to Reinstall/Repair XP
I'm assuming you have quite a lot of computer savvy??? You'll need to access that drive and get the original key off it. Try connecting the drive to another pc and see if you can get to the Windows folder. Once there, use Jellybean Keyfinder to navigate to the Windows folder in that drive and take note of the OS key. From there you can reformat and use the existing key.
Apr 30, 2009 | Dell Dimension 4500 PC Desktop
My Dell Dimension 4500 won't start unless I take the cover off the hard drive and mess with the wires. Is it time to buy a new computer?
The green light means or is supposed to mean that the PSU is getting power and working properly. Unplug a few devices such as the CD drive and/or the Hard drives and see if the computer powers on. I have seen a fair number of Dell PSUs just fail, they keep putting out the right Voltages but they don't put out enough power anymore. Do you have a spare and comparable PSU lying around?
Mar 18, 2009 | Dell Dimension XPS 600 PC Desktop
Partitioning a second hard drive
"No need for third party programs to partition hard drive today we will look at how to create partition in Vista for free."
http://askabouttech.com/how-to-partition-hard-drive-in-vista/
Mar 05, 2009 | Dell Factory Refurbished 4500-7MMF821...
Primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Jan 30, 2009 | Dell Dimension 4550 P4 Socket 478B...
Formatting my Dell Dimension 4500
sure..boot from an install or recovery cd..and format it from there
Apr 28, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
109 people viewed this question
Alun Cox
