Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Need help with wiring on Hunter 44110
I just replaced my Honeywell with a Hunter 44110 and had all the wires marked and a couple fell off so now I have two wires that I'm not sure where they go.  I have AC and gas furnace.
Current lettering on Hunter is G, RC, RH, Y, W.  There is a red jumper between the RC and RH.
I have a yellow wire that I connected to the Y, a red wire that is connected to the RH so that leaves me with a blue wire and a white wire that I'm assuming connects to either the G or the W since that's what I have left over.  I'm needing to know where to connect the blue and the white wire, to the left over G and W?  Need some expert advice for this do it yourself female.  I hope this makes sense.
Want to replace american strandard thermostat with codes R-red,G1-Green,Y1-Yellow,W1-White,W2-Blue to a Hunter Md#44110 with codes G,RC,RH,Y,W what wires go where. Thank You ,Dennis
Posted on Feb 09, 2010
  • 24 Answers
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Posted on Apr 16, 2009
Not working
"G" terminal is for the fan, typically using a green wire. "C" terminal is the common, basically a ground, typically using a blue wire. Also, leave in the jumper between "RH" and "RC".
May 19, 2010 | Hunter Fan Company 5/1/1 Programmable...
Im replacing my honeywell with a hunter 44110 the honeywell has 6 wires w1 to white, w2 to blk, G to green, RH to Red, Y2 to yellow and Y1 to orange, the hunter only has G RH RC Y W
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Hunter Fan Company 5/1/1 Programmable...
I have a Red, White, Blue and Green wire , need to wire a Hunter B01 MOdel or 44110 Thermostat has the following ports available G, RC, RH (RC & RH Have a jumper between them), Y/O, W/B, Y/1
From what you describe you have a heat only system with no AC. If that is so, then you would wire it as follows.
Red wire = RC (leave the jumper in place)
Green wire = G
White wire = W/B
Blue wire = is unused because the thermostat is battery powered and does not require a common wire.
I reccomend you consider not using the Hunter T-stat. They are so extremely problem prone and unreliable. You will be much better off with a Honeywell or White Rodgers T-stat.
You will also need to program the Hunter T-stat for your system per the instructions.
Oct 04, 2009 | Heating & Cooling
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Jun 30, 2009 | Heating & Cooling
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
I am replacingh my thermostat. it's a honeywell xt302c. im replacing it with a hunter 44660. the wires are different letters. here's what's hooked up on the honeywell and available on the hunter: Honeywell...
Thanks for your Question,
B- is your common leg,
RH- is your hot to heating
RC1- you will not need
RC- you can use if you remove the jumper for cooling
Y1- you will not need
G- is your fan
O is not needed, wires should be hooked in as follows,
RH- red wire, heating
RC- Yellow wire, Cooling
G- Green wire, Fan
B- Blue wire, for common leg, this one might be a different color so make sure at the furnace which T-Stat wire is connected to Common, you should check all the wiring at the furnace to make sure this pattern of wiring is followed, it should be standard practice to hook them up this way, but not all installers do it, thanks again, please rate this,
mr.grzz
Jan 25, 2009 | Heating & Cooling
New thermostat not starting compressor
With the jumper inplace does the compressor start? What about without? Unless you have more than one transformer you should leavethe jumper.
Dec 06, 2008 | Heating & Cooling
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,084 people viewed this question
Top Hunter Dryers Experts
Fan Fair Of Boca
Fan Fair Of Boca
Paul Bade
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
