Question about Acer Aspire 5315 Notebook
Can not connect to the internet
I just purchased an Acer Aspire 5515, with built in high speed wireless LAN.
Do I need to purchase a router to use within my home or at wi-fi areas? If so, what kind should I get?
    President:
  • Acer Master
  • 1,314 Answers
In order for you to use your built in wireless card on your Acer, you need to have a way to convert your internet connection in your home to a wireless LAN so your laptop can see it and connect to it. This is done with a wireless router. They are relatively inexpensive and simple to set up.
In order to connect at public wi fi areas such as those that are found at hotels and starbucks, then all you need to do is turn on your computer and make sure your wireless is turned on on your Acer. It should automatically alert you to any wireless signals it finds and you can connect that way.
Thanks for using fixya. Please take a moment to give this solution a rating of fixya since your question has been completely answered. Thanks.
Posted on Mar 08, 2009
  • 679 Answers
Your home yes, WiFi hotspots no, they already are using a router to give you access. Get a Linksys Broadband router, the WRT54G is the old standby, but they have a new sleek model, "same price", with no antenna's sticking up, it is basically the same, but looks very modular, not like a clock radio, with antenna's sticking out. I would still select the 4 port model, in case you want to hardwire, a desktop, for a server.or a print server, They run about $50.00 at most electronics stores.
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Is this laptop equipped with wirless connection fromthe manufactorere or must it be purchased
Most late model Acer Aspire laptops have G or N WiFi included in the computer. My Acer 3680 series has it built in (G) and I added a D-Link N card to it to speed things up.
There should be a switch on the front or a Fn Button that turns on the WiFi.
Dec 18, 2010 | Acer Aspire 5335-2257 Notebook
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
HELP! I just purchased an Acer Aspire One from a
you need to reinstall driver of your wireless card. since other laptop can connect to the router. make sure also that the WEP/WPA key is correct, if theres any.
Apr 03, 2010 | Acer Aspire One Netbook 8.9" Notebook
Do I need a modem to connet my wireless acer aspire one to the high speed connection I have at home?
What you need is a wireless router. Your high speed internet connection at home might have a wireless router built into it, but some don't. What kind of internet connection do you have? what's the model of the modem you have. If you're not sure, just list the model numbers of all of the devices you have running.
Mar 04, 2010 | Computers & Internet
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
Jul 31, 2009 | Computers & Internet
Want to download wireless internet to the system it is rum by windows 2003
What you need first is to install the wireless driver for your wireless card in your computer. If you don't have one you need to purchase a wireless card.
Then read the following info to decide what type of Internet access you require.
Wireless connections to the Internet can be achieved by several methods and it depends upon the method of delivery by the Internet Service Provider in your location.
The most common is by DSL and cable, the modems that are used with DSL and cable connection can have a built-in wireless router. Your computer will require a wireless card to connect to the modem/wireless router and the range is restricted to approx. 100 ft depending where the wireless router is located within the building.
The laptop's wireless card can be a built-in device or a plug-in device eg a PCMCIA card or a USB device. and these can also connect to a wifi hot spot in locations such as McDonalds. Star Bucks etc.
There is another method that can connect into the Internet that uses a USB wireless device that connects to a G3 network, bacically a type of mobile transmission and the device is locked into a specific Internet Service Provider. This method gives a wider mobile range (even across states) of connecting to the Internet but usually at a higher cost.
Basically you need to see what the Internet Service Providers offer in your location. Beware of the costs of the various plans they offer in broadband speed, their download limits and the penality for exceeding the limits etc.
When you decide which method you choose, you need to consider setting up your wireless network securely to prevent unauthorized access.
May 08, 2009 | Acer Aspire 3680 Laptop
Definition of the sound card, internet lan & wireless lan
The definition of the sound card, is a chipset integrated into the main board of your laptop, in order to provide sound to your built-in speakers, or to the headphone jack on your laptop. Internet LAN (or Local Area Network) is a port located either on the side or the rear of your computer, where you would plug in a Cable/DSL High-Speed Internet connection, using an Ethernet cable (also called RJ-45). Wireless LAN is the same idea, only instead of using an ethernet cable to provide you access to the internet, it uses a wireless signal or radio frequency, to connect to a wireless access point (usually provided by a wireless router in the area). More in-depth information can be found at the following links:
Sound Cards: http://en.wikipedia.org/wiki/Sound_card
Internet LAN: http://en.wikipedia.org/wiki/Ethernet
Wireless LAN: http://en.wikipedia.org/wiki/Wireless_LAN
May 06, 2009 | Acer 4220-2346 Notebook
Cannot connect to internet
u must purchase a router so tat ur laptop dont hav tobe wired u can move freely any where in a spefied  distance
tat wil be useful
Mar 08, 2009 | Dell Inspiron 8600 Notebook
Acer Aspire 5315 Notebook Logo
200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
