Question about Toshiba Satellite A105 Notebook
Toshiba Satellite A105- S54014
I have this computer and when it turns on, the windows logo loads about 1/3 way and I cant make out the message and it shuts off. Over and Over again. It will not turn on. What can I do?
  • Toshiba Master
  • 32,281 Answers
Press F8 function key several times as the computer turns on and when you get a list of options select Last known good configuration the press the Enter key.
If Windows then boots up properly then re-install the latest Windows Service Pack (SP3 for XP, SP1 for Vista).
If all fails then re-install Windows.
Posted on Mar 09, 2009
How to factory reset my Toshiba Satellite A105-S4384
Put Recovery Disk 1 in the CD/DVD drive, then power off your computer, unplug everything from the unit including the AC, remove the battery, press and hold down the power button for 30 seconds, replace the battery and then AC, power on, at the Toshiba logo screen press 'F2' to enter the BIOS Setup, in setup press 'F9' to load setup defaults, press 'F10' to save and exit, now at the Toshiba logo screen press 'F12' to enter 'Boot Sequence', with the up and down arrow keys to select 'Optical Disk Drive' or 'DVD/CD Drive', you will then see 'Press any key to boot from CD/DVD drive...' with the dots counting down, press any key before the count down finishes. Assuming you get back to the Toshiba Recovery Utility menu, select the 'factory default' choice, and return your unit to its out-of-the-box state.
Jul 01, 2014 | Toshiba Satellite A105-S4384 Notebook
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
Toshiba Satellite A105-S4014 15.4" Notebook with
If the drivers aren't loaded, it won't work properly.
Please check your model number as I cannot find it on Toshiba's database.
Try www.computers.toshiba-europe.com and let Toshiba detect your model.
Toshibe supports most models.
Nov 17, 2010 | Toshiba Satellite A105-S4014 Notebook PC
I need a mother board for a Toshiba A105-5101 and a price. thank you
found one here
http://www.laptop-motherboards.co.uk/product_153-1-4_Toshiba-Satellite-A100-A105-Motherboard-V000068120.htm
note that this is not the exact same board that you have, you would need to contact them to confirm the part number.
price is just under 250 us $
May 08, 2010 | Toshiba Satellite A105 Notebook
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba A105-S101 freezes at start up!
I would first attempt to reinstall the software from the install cd. Your Toshiba support page is recomending a new BIOS upgrade. See below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209144&rpn=PSAA2U&modelFilter=A105-S101&selCategory=3&selFamily=1073768663&selModel=1209144|PSAA2U
Dec 25, 2008 | Toshiba Satellite A105 Notebook
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
TOSHIBA A105
maybe the shop formatted the hard drive including the recovery partition where all the files should be .so your disc cant find it .
if you can boot up into safe mode then use windows restore function to restore to an earlier time,if not you may have to get a set of recovery discs from toshiba
good luck
Terry
Mar 23, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
