Question about Maytag Neptune MAH5500B Front Load Washer
Front loading Maytag Neptune doesnt drain all water
I bought a used maytag neptune front loader. The first cycle I ran with a washer cleaning product (no clothes) but the washer wont drain all the way out. Alot of debris was flushed out. I am not sure if the pump is clogged or if it could be something else. What can I try before calling a repair man?
  • KCNY Mar 19, 2009
    I have the same problem, water remains in the drum. When the washer goes into the spin cycle it continues to pause a bit as it countdowns on the timer. Cloths remain a bit soaked it begins to spin again same thing happens it shuts down only to restart the spinning process with less time on the spin cycle timer. It does this over and over again until there is no more time on the spin cycle timer and the cloths remain a bit soaked. Even after I competely removed the pump and cleaned it out though there really wasn't much of anything in it. I also removed the drain hose from the drum and found no clogs. The plumbing pipes where the drain hose is attached and discharges all the water from the wash cycle is clear as well. I learned how to do all that from having professional repairmen here numerous times. One repair man felt so bad he was here so often fixing one problem after another that he taught me how to remove the pump and drain hose and troubleshoot the machine prior to giving up and calling for his help. This time I have tried everything short of replacing any of parts including not replacing parts on the mother board. I'm totally done with this neptune washer, you'll find it at my curb tonight...it's trash!
The washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Posted on Mar 09, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag Neptune washer front loader has been great but my wife pointed out that it doesn't drain all the water out? The thought of that old water under the spinning basket (dont know the tech term) doesnt...
Yes, the Neptune is a great washer, arguably. :-> You just may have a clogged pump. Pull the back panel and the rest is evident. Pull baffles, remove gookus, pull pump, clean, etc. ...just like a plumber. Be sure to pull the rubber baffe directly from the bottom of the outer tub. You may need a wet/dry vac to assist you. It's a bear of a job but I do it all the time.
Rich
Western Appliance Repair
Washer Repair Meridian
Oct 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front lader washer maytag neptune
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Remove the pump and clean it out. Access the pump from the rear.
May 25, 2009 | Maytag Washing Machines
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Maytag front loader washing machine. Mould
How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
670 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
