Question about Hobart D300 Stand Mixer
Need a replacment pin that holds the hook on the shaft
    Problem Solver:
  • 17 Answers
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw some pinion keys (pins) for the agitator shaft. Even a whole kit to replace it if necessary. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Posted on Mar 08, 2009
Hobart h 600 mixer dough hook keeps coming off during operation. What would cause this
Take a look where the agitator pin engages with the dough hook.
Either the agitator pin (sticks out from the agitator shaft) is worn out or the groove in the dough hook where the pin should sit has elongated and worn. Either pin replacement is in order or new hook is required...possibly both.
Jul 04, 2014 | Food Mixers
Agitator shaft replace
Yes
If you have not gotten this taken care of yet. Turn your mixer upside down and remove the silver drip ring and then take out the drive pin with a punch, the pin holds the planetary on and in place. now with 2 screwdrivers from position 5 o'clock and 7 o'clock gently but firmly pry up until the planetary breaks loose and comes of the center shaft, now you will need some snap ring plyers to remove the agitator shaft, once you look at it you will see how to take apart easy.
Feb 11, 2013 | KitchenAid K45SS Classic Stand Mixer
The pin on the shaft that holds mixer attachments broke off
You need to replace that shaft. The parts are available online, but the planetary takes a skilled repairman to disassemble.
Jun 28, 2012 | Dito Dean Food Prep EM-30 Stand Mixer
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
Hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Sep 25, 2009 | Hobart N50 Stand Mixer
I cant remove the hook mixer from the shaft it was not taken off after the last time it was used and now is stuck on any ideas
Renato20,Either the hook is worn or the beater shaft pin is worn or dough has built up around the pin/shaft and is stuck.I'm a hobart tech and if i came to your place,first i would use a rubber mallet and hit the outer edge of the hook upwards and see if i could free it.If that does'nt work i would heat tghe hook up with a torch and beat on it up,If that does'nt work i would cut the shaft and replace the shaft and hook.I bet if you beat on it (takes time) you will get it off.
Mar 09, 2009 | Hobart D300 Stand Mixer
Bosch aluminum dough hook has black coating
the problem is where the pin on the beater shaft locks into the hook may be wearing down or the hook itself.when you put the hook on see if you get alot of play in the hook (wiggle it and if it feels really loose its worn).its still safe to use but eventually (and this may be quite sometime) the pin may break off the beater shaft.you would then have to replace the pin and hook.
Jan 27, 2008 | Bosch 700 Watts MUM6622 Universal Series...
Hobart p660
There are 2 set screws.Make sure their both out,if for some reason there is only 1 set screw these are your options.Heat the shaft and remaining pin with a mapp torch (you can buy them at home depot,lowes for $40 bucks),heat it up really good then get a punch and try to knock out the pin,option 2---if you cant get the pin out then youll have to replace the shaft and if thats the case you should also clean out the planetary and replace the bearings and seals.If the hole in the shaft is oblongated or worn you should probably replace the shaft because the dough hook will rock the pin back and forth breaking the pin.Also look inside the hook and make sure thatI its not worn out where the pin sets.IF you see thee hook or shaft pinhole worn you will break the pin again if you are able to replace the pin.I work for hobart and service mixers regulary,if you need part numbers or advise let me know.
Nov 27, 2007 | Hobart P660 Stand Mixer
Hobart D300 Stand Mixer Logo
115 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
