Question about GE Home Security
How do I replace the battery in my Simon XT security system
How do I replace teh batterys in my Simon XT Security System
  • Anonymous May 18, 2009
    need to change battery--tech support not open
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 31 Answers
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Posted on Jan 06, 2015
  • 5 Answers
SOURCE: System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Posted on May 19, 2008
SOURCE: Simon 3 "System Low Battery" after 3 years use
I have the same Security System the same problem, with the 2 beeps every couple of hours .
The Control Center called and said the battery on the door connector was low and that was the cause of the beeps not the entire system, I replaced with 2 triple A batteries and no more beeps.
Pauline
Posted on Nov 08, 2008
  • 3 Answers
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Posted on Sep 28, 2009
  • 14 Answers
SOURCE: sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Posted on Mar 14, 2010
Simon XT "system low battery"
IT might be testing ok, but you need to load test it. It could be the charging circuit but in most cases the battery will show a surface charge that is ok for a short period of time.
Feb 10, 2014 | GE Security Simon Xt Wireless Control...
Simon xt arms itself
there is an auto arm feature programmed in to the system. Check your setting and the system clock.
Dec 30, 2011 | GE Simon XT Wireless Home Security System
Will the sencors that are on 60-875 work on simon xt system
No,sorry they are totally differnce in system datas programming.
Nov 24, 2011 | GE Security Simon 3 Wireless Home Security...
System says low battery ... how do I open it to replace batteries...very confusing!
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
Jan 05, 2011 | GE Security Simon Xt Wireless Control...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
Where is the battery located in the Simon system?
Hi.
The battery is located inside the Simon. Use a flat screwdriver to remove the panel.
Here an online manual.See page 23.
Connect the battery BEFORE connecting the power transformer.
Regards.
May 08, 2010 | GE Security Simon 3 Wireless Home Security...
GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
AlarmProfessor.net
Apr 16, 2010 | GE Security Simon 3 Wireless Home Security...
How do I change the battery in the GE Simon XT panel?
If your system is monitored call the central station first and tell them you are working on it. Then push down on release tab in top center to fold down the front face. Nest step is to use a small flat blade screw driver to push in and release the tab again in the top center and the unit will fold down towards you, hold on to it and you will see the battery compartment. Follow the red and black wires to the battery. Some units have a plastic lid over the battery that requires you to remove to small phillips screws to remove battery.
Feb 21, 2010 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
470 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
