Question about Kenmore 15864/15862 Top Load Washer
Kenmore Series 80 washer won't drain
Our washer won't drain. There is a little triangular opening on the right of the washer. Using a butter knife, if we push down in that little opening, the water will drain. The washer goes through all the cycles fine, just will not drain. Nosing around lead us to find these two clips (or one held together by a screw) that appears to be missing a screw. I don't know what this part is called (is this the lid switch??) so we can't order it. Does anyone know what this part is called and is it difficult to repair? Model #:110.29852991
Thanks!
(Hope someone can anwser....starting to stink around here!!!)
    Genius:
  • 1,066 Answers
You either need the lid switch or the plastic part that pushes down on it.  an easy fix order it from Sears.
Posted on Mar 08, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Washer machine
i have E7 err
Jun 30, 2013 | Washing Machines
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
How do I replace the lid switch on kenmore 80 series?
Hi and welcome to FixYa. Before you start UNPLUG the washer. There are 2 ways to open the top of the machine to gain access to the lid switch. The easy way is to grasp the top inside the top of the wash tub with the lid open pulling hard toward your waist and up. It usually opens right up. Some of them can be stubborn and you have to use a putty knife to release the spring tabs located about 4 inches from each top corner in the space between the cabinet base and the top panel. Press in on the tabs one at a time with the putty knife and pull up. The top will open. Then it is a matter of removing the mounting screws and connecting the new switch.
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
227 people viewed this question
Sal De
fordexpert
Robert Rankin
