Question about Singer 8280 Mechanical Sewing Machine
8280 stopped...no pedal power even though light is on.
After hitting walls from Singer's talktous@singerco.com and Singer repair service center on my six month old Singer 8280 I refused to pay the $79.95 charge for the service center to take it apart when I paid $89.95/99 for it in Sep 2008. Singer sent a new pedal cord connector after several days of going back and forth to prove I am the only and original owner. By then I had taken the machine apart myself up to the front casing looking for something broken. I had the same complaints the other postings have had with thread problems several times before the machine quit. I found a large gob of grease at the back of the bobbin on the drive shaft tangled up with thread in it. There was grease all over the back area and around the back of the bobbin. I cleaned it up and wiped it out, put the machine back together with three screws left over...no biggie then connected the new pedal when it arrived. It sewed 8 inches and stopped. Died. No power to the pedal, but the light was still on.
An email back to "talketous" came back to me saying the problem is in the power outlet connection then, and I would need to take it or ship it to a service center to have the outlet replaced. I asked them to send me a schematic of the power outlet connections and the part number of the outlet so I can replace it myself along with instructions on how to get the last part of the front casing off because there is one area close to the feeder plates that will not release. If I can get this casing off I can check and replace the power plug connector. And Oh Yes I learned the two year warranty is virtually useless that the repair center will only honor it if it is sent directly to them from Singer.
This machine was headed to the dumpster area until the email came in telling me a replacement foot pedal had been shipped. Unless someone has some answers on this it will soon be dumpster fodder. I am looking for a gear or belt driven electric machine now. I'm irritated.
5 Suggested Answers
SOURCE: Singer Futura CE-250 Connection Error
I just had this same problem and tried the above - didn't fix it. So, I put the software into the CD drive and re-connected the usb from the sewing machine to the computer. Windows then prompted me to allow it to install the hardware (this really means install the little program that is called a driver which allows your computer to talk to a piece of hardware.) Windows found the driver on the CD all by itself and within minutes, I was ready to go. Why did our machines do this?? Probably a Windows update recently erased the info need by the computer, so it had the re-install the driver for the sewing machine.
Worked for me - I hope it works for you!
Posted on May 20, 2008
SOURCE: Singer 2010
If model 2010, the problem is a part metal- part plastic part attached to the bottom of the bobbin winding lever, the white tear-shaped thing with the arrow on it. If that will turn past the center of the bobbin it's broken inside. to try a do-it-yourself fix, turn upside down, remove 4 screws, including one by the plug (which must be pulled out for safety anyway) remove bottom case. looking at left end of the works, move the bobbin lever and you'll see the broken part move. The plastic part should be broken about half-way down. You can see how the part should push the white plastic bobbin winding shaft up and down when lever moved. the part can be removed by loosening the 2 tiny hexnuts holding it on the metal shaft. you'll need the smallest size allen (hex) wrench there is. NOTE where the part is at bottom of the metal shaft for when you put have to put it back on. be careful to hold the bobbin winding shaft itself in place, but it's easy to see how it goes back in if it pops out. if the break is clean (like my wife's that I just fixed this way yesterday!) you can put a drop or 2 of good crazy glue in the break, making sure lined up on the sides, then clamp in a vise (or hold firmly together with pliers) for at least 10 mins, longer better. wait at least an hour before putting back. putting back on is a little tricky but you move the bobbin lever to left (open) position, make sure it's just on the end of the shaft (shaft barely protruding) and see where the part isn't pushing the bobbin winding shaft. re-tighten with hex wrench then see if the repaired part now pushes the bobbin winding shaft up and down when you move the lever back and forth. Turn back over and move the lever without a bobbin spool- you should see shaft move up in the middle of bobbin case where it will engage the bottom of the bobbin spool where the x is.
Now if part can't be fixed it is available from auth Singer service center in you state but runs $40 or so. they'll try to tell you they have to install it because of special anti-static gloves that wont fry your motherboard on the machine's computer, but the center in Michigan finally said they would mail it to me. hope this helps! funny I just saw this after fixing our machine which hadn't been used for a long time until I decided I might as well look inside if I was going to have to buy her a new machine!!!
Posted on Nov 24, 2008
  • 980 Answers
SOURCE: I have a Singer 6268 electronic machine (25 years
The nylon timing gear may have broken up or the top gear amy have broken up, you need to get into the top and have a lokk and also under the bobbin case area in the bottom of the machine, iof thge gears have broken you can buy the gears quite cheaply and fit them yourself, I do have full instructions to retime the machine.
Ken
Posted on May 17, 2009
  • 980 Answers
SOURCE: Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
What size needle for Merritt singer 3014
I could not find a Singer Merritt 3014 nor a Singer 8280. Do you have the serial number and/or model number? You can always try this site:
http://www.singerco.com/products
Jun 11, 2014 | Singer 8280 Mechanical Sewing Machine
1952 singer manuel
If you're in the US, contact Singer Customer Support at 1-888-633-8635 Monday through Friday 8AM to 4PM CST.
Nov 04, 2013 | Janome Sewist 625e
Demo for Singer 8280 sewing machine
Your machine can be found on the Singer web site here: http://new.singerco.com/products/detail/1337
There are links to instruction manuals and accessories on that page. You can also post in the Reviews and Question/Answers section on the bottom of the page to solicit feedback and help from Singer experts and other users.
Hope that helps!
Jun 21, 2010 | Singer 8280 Mechanical Sewing Machine
Singer sewing model.
Probably not worth much. I have found them setting out for the garbage truck.
You can try here - Email Singer at: TalkToUs@SingerCo.com
Mar 13, 2010 | Singer 3116 Simple
The thread keeps knotting up near the bobbin on my older model singer
Sounds like a tension problem. You may can email the singer company at talktous@singerco.com
Jun 24, 2009 | Singer Sewing Machines
Thread gathering in ball under fabric It is singer futura 150
sounds like a tension problem. You can call 1-800-4SINGER. The singer rep. should be able to help.
Or email at talktous@singerco.com
Aug 31, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer Futura 100
You can call 1-800-4SINGER. It will take a while to get thru, But the rep, should be able to help. Or email at talktous@singerco.com (that's talk to us @ singerco.com)
May 08, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer 8280 Mechanical Sewing Machine Logo
115 people viewed this question
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
