Question about Micro Electronics WinBook Si Notebook
Winbook Si laptop - are 12.1" and 14.1" screens compatible?
I have an 850 MHz Winbook Si laptop with an apparently flaky motherboard.  Another 850 MHz Si is available, but it has a broken 12" LCD screen.  It appears that I can physically replace the 12" screen (and the lid) with the 14" one from my Si -- would it work?
Can use my on moto g 16 gb on tracfone
Hello Garry!
To answer your inquiry, the compatibility will depend on the model that you have. Let me share with you the bands that Moto G uses, please consider if you have a CDMA or a GSM version.
Global GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
US GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
CDMA Model:
CDMA/EVDO Rev A (850, 1900 MHz)
Also, I kindly recommend you to verify with Tacfone, if your device will be compatible with their network.
If you need further information about the specifications of your device, please follow up this link: http://bit.ly/MotoG-specs
Hope this information is helpful for you.
Best regards,
Liz
Motorola Support
Nov 13, 2014 | Motorola Mobility Moto G 16 GB Black...
It is a winbook xl when i power it on the battery light turns on not any other lights i dont see any thing on the screen or hear the harddrive or any thing not even a beep i need help the laptop is about...
Without seeing it, I'd guess the power unit might have failed, or it could be the motherboard. Modern computers have a system management controller you can try resetting, but on a 15 year old laptop I don't know what the equivalent would be, if it even exists. If it's the motherboard chances are it'll be cheaper to buy a new computer.
Jul 28, 2013 | Computers & Internet
Replacing dvd drive
Most times there are a few screws just below the drive. Open the drive, remove the screws, the drive should slide out. It'll be a little stiff at first until it's unplugged.
Oct 22, 2012 | Micro Electronics WinBook Si Notebook
Sometimes screen come on and sometimes it doesnt but u move the screen flat and back up it mite come on
There is either a break in the screen cable or a loose connection, you will need to strip down screen front to access these
Feb 03, 2011 | Micro Electronics WinBook Si Notebook
Can i upgrade my amd duron 850 mhz to 1.4ghz?
yes, depending what motherboard you have. almost all of them will support 1.4 ghz
Jan 01, 2011 | AMD Duron , 850 MHz Processor
My winbook wont charge
turn off remove the battery
plug in charger and see if laptop turns on
fiddle with cord to see if laptop cuts off. If so you need a new charger or
the jack in the laptop has a short.
If if stays on the battery may be bad
Nov 08, 2009 | Micro Electronics WinBook Si Notebook
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
Aug 20, 2008 | Intel SuperMicro SUPER Motherboard - 810...
Motherboard
Hi michlionfan, the following link shows what CPU's your Foxconn 661MX board can handel.
http://www.foxconnchannel.com/Upload/Compatibility/200607120855293005661MXhtm.htm
Link to foxconn 661MX motherboard site.
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000114
From this site, look to the left & find the words, Main Page typed in green. Under these two words is, compatibility. Click on it.
Best wishes!
If you need any more help feel free to post here or click the ask me button.
Mike
Apr 17, 2008 | Foxconn 661MX Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Micro Electronics WinBook Si Notebook Logo
121 people viewed this question
Top Micro Electronics Computers & Internet Experts
Dennis Maeder
RSole
Masood Rasool
Level 1 Expert
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
