Pls my files are there i need to unlock it
SOURCE: Just a good HP iPAQ hx4700 Disassembly, Screen Removal and Repair guide
Thank you! This is a really good page!
SOURCE: hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1
and 4) down at the same time, then insert the stylus into the little
hole on the bottom and press gently. Hold all for 4 seconds. The screen
should begin to fade. Now release all. If successful, you will not be
able to start the machine by pressing the on button. You will have to
reconnect to ac power to start it.
That is all there is to it.
SOURCE: on IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "Thank you so much! I really appreciate your help as I don't have the manual for this particular IPAQ model. "
