Question about Sharp AR-M205 Copier
Copier Sharp AR-405 Plugged in but doesn't go on
The machine is plugged on the outlet but when I turn the switch on it clicks only, I was told that it could be the Power Converter, no idea what that is. I wonder if it is worth to fix it. Please help
  • Anonymous Apr 20, 2009
    Copier Sharp AR-405 Plugged in but doesn't go on, it only clicks.
  • 29 Answers
If you hear a click when the switch is turned, on if the toggle buttons flips back replace this part (you can get them at perecison roller phx az , if this does not fix the problem you may neet a new power supply but you usally get rotaiong stars on the display or a frozen panel note there is 250 v fuses on the power supply and i have seen thses blow
Posted on Mar 09, 2009
    President:
  • Sharp Master
  • 990 Answers
Hello sir; When you switch on , does control panel light on ?if not ,check the power switch, or the fuse on power supply board.
Posted on Mar 08, 2009
Sharp ar-m700 no power
canon ir 3300 machion no display
Jul 15, 2013 | Sharp AR-M700U Grayscale Copier
Can you print through a wireless connection on a Sharp AR-405?
You first would need to make sure the machine has the opional printer expansion board installed. Make sure you have ethernet connectors on the rear leftside of machine. If so you could possibly install a wireless bridge to the machine if your network supports it. Some networks such has Verizon blocks them. A bridge is about a $100 dollars and they walk you though the install just follow the directions.
Aug 30, 2011 | Sharp AR-M205 Copier
How do i clear a F9-00 code for the sharp ar-bc320 copier?
Put the machine in test mode with the following key sequence:
P - * - C - *
then, 14-Start ... Execute ... Yes
CA to reboot the machine. For good measure, shut the power off, wait, and turn it on.
PS. - Get your copier on its' own outlet and share it with Nothing!!
Jun 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
AR-405 copy machine has a L-6 10 error message. How do I reset copier?
It can not be reset, the problem is in your polygon motor at the laser unit, you should replace it
Jun 05, 2009 | Sharp AR-M205 Copier
I have a Sharp AR-336 that's showing me F1-00 error code. What is this and how do I fix it?
F1-00 is a communication error between the copier and the finisher. It could be a loose connection (wire that connects finisher to copier) or it could be worse like a failed board. It could be the finisher board or the PCU board on the copier.
Make sure the finisher cord is firmly connected to the copier.
Make sure the copier is not plugged into the same wall outlet as another piece of equipment that might be drawing excessive power. do not plug into a cheap surge protector with other items.
If problem persists call a tech.
Hope this helps
Apr 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-405 error code F1-15
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Feb 16, 2009 | Sharp AR-M205 Copier
Sharp AR-336 copier was moved, now it will not power on
no, its possible you blew an internal fuse in the machine. only one power switch.
Jan 22, 2009 | Office Equipment & Supplies
MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE AND BLINKING RED TRIAGULAR LIGHT POINTING TO TRAIL
Some part/ unit (developer, drum, imaging unit, fuser) or something else is not installed properly or is not plugged into the machine. Check all assemblies that can be removed from the copier, and make sure they are installed and plugged in properly.
The 'ch' code will automatically reset when the fault is found.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-156 will not copy
Usually that means the polygon motor isn't up to speed.
Try turning the copier off, wait 20 seconds, and turn the power back on.
Is there any other devices plugged into this electrical outlet?
Oct 27, 2008 | Sharp AR-156 Copier
Ar405 error code f2-31. how do i solve this problem
problem sharp AR 405 copier error code f2-31 copier. How do i solve this problem.
Sep 09, 2008 | Sharp Office Equipment & Supplies
Sharp AR-M205 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
