Question about NAD Audio Players & Recorders
Where can I get a belt for my NAD 5355 cd player?
    Genius:
  • 1,175 Answers
Hi...
Try part# SBS3.0 from studiosoundelectronics.com
or a similar part at mcm electronics.
I just did one this week.
Posted on Mar 19, 2009
Is it the belt that opens the disc loader, if so you can use any old rubber band to fix it
Posted on Aug 13, 2009
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
NAD 5355 loader not functioning due to stripped gear
Hi ...
Contact NAD parts thru their website.
or
oaktreent.com might have spare parts.
Mar 12, 2009 | NAD C521 CD Player
NAD 5100 monitor wont eject
Hi ntravers9
You could fix this yourself, in saying this of course, you will need to also source a new belt for the player ( I can help you there too) That is probably what is preventing the Cd tray from opening. If you where to remove the lid, and give the transport a little assistance in the direction that things initially start moving, then you can be sure that the mechanism is not damaged in any way, and that a lazy belt is the source of you problem.
Do this if you are into fixing it yourself, to see for sure what is happening and we can go from there.
regards
robotek.
Dec 17, 2008 | NAD C521 CD Player
NAD C542 CD PLAYER
maybe it is just the belt for the tray motor.
Jun 27, 2008 | NAD C542 CD Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
604 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
