Question about AMD Athlon XP-2500 1.833GHz 512K 333MHz CPU Retail AXDA2500BOX (XP2500BX)
Computer will not start untill several times of turning on .
What is the most likely problem with this computer?
  • glenn hoffman
    glenn hoffman May 11, 2010
    hi, what does it do? i did not see all you wrote, several times of...
  • 28 Answers
Yes check whether ur ram or part loose or not......tif yes then plz tight it......& if it doesnt works ......try to check cpu current wire........or change...
Posted on Mar 09, 2009
Our 2007 pt cruiser had computer replaced, and now the car will not shift gears, we check tran fluid optimal level, turn key back and forth several times until it says done. then drives normally.why?
On new cars there are several ways to reset the computer. I got a truck I have to turn key on and hit gas 5 times fast and 30 seconds, and then start it. *What always works is to disconnect battery- Negative(black first) then the positive (red side)-(do not let touch sides of metal firewalls). after 30 + seconds hook it back up and it should reset the computer.
Aug 27, 2017 | Cars & Trucks
Monitor does not show images when computer is turned on until computer is re started sometimes several times, and/or several keys on keyboard are hit.While screen is black a ticking sound is...
Likely a bad power supply board, and that is almost ALWAYS a bad capacitor on the board. They cost under a dollar to purchase a replacement.
Before you fire the computer up next, try running your hair-dryer (yes, your hair-dryer!) and blowing hot air into the innards of the monitor.
If it starts then with no problem, you have "aced" what it needs for a proper repair: a new capacitor on the power supply board, and you can Google for the parts and the instructions.
Mar 07, 2015 | Computers & Internet
I disconnected my battery in 08 tundra and now it wont idle
disconecting batt resets the computer. now it needs to learn how to set everything to run again. disconnect batt for atleast 60 seconds, re atach, start car it will start and die(dont press gas) do this over and over until it idles (could take up to 10 times). by pressing the gas you make the computer think it is idling to high so it keeps turning down the idle. it will idle fine after reseting computer and starting several times without hitting gas peddle.
Mar 09, 2013 | 2000 Toyota Tundra
Turn on safe mode
After starting your computer hit F8 several times until the boot menu comes up. Then just select "Safe Mode"
May 23, 2012 | Fujitsu LIFEBOOK LH531 14 Notebook - Core...
RECOVERY FACTORY
Hi there!
Here are the steps to restore your computer to factory default:
Windows XP
- Turn on Computer
- during startup you will see the Dell logo, press <Ctrl> <F11>
- click Restore then Confirm
- let the computer finish starting
Windows Vista
- Turn on Computer
- during startup you will see the Dell logo, press <F8> several times
- select Repair your computer
- select keyboard layout then next
- log-in as local user
- click Dell Factory Image Restore
- Click Next and confirm data deletion
- wait until it finish
Apr 11, 2011 | Dell Vostro 1710 Laptop Computer PC...
Computer will not start up completely.
You could have a problem created by whatever you wer doing last. Try hitting F8 repeatidly until it gives you get the "Advanced Options Menu" Then select "Last Known Good Configuration" and hit ENTER.
Good Luck
Apr 30, 2010 | HP Compaq Presario 2200 Notebook
Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Mar 13, 2009 | HP Office Equipment & Supplies
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Computers & Internet Logo
29 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
