I haven't used the microphone for a long time, and now I am trying to use it and it doesn't want to turn on. I have tried three different kinds of cables and it is still not working. What should I do?
  • jacor53 Mar 08, 2009
    yes
    It's a SHURE SM81, I paid a good amount of money for this and I'm shocked that it has just stopped working.
  • 201 Answers
What is the equipment that you are plugging the mic into, and have you used the exact same setup successfully previous to this?
Posted on Mar 08, 2009
  • 19,396 Answers
You have two year warranty, and if this is a factory defect they will replace the mic the same. Contact shure.
  • 1,800 Answers
Hello Sir.
i'm not gonna quote from this but ithng the solution is here and also best steps and advises and tricks for ur Shure Mic.
The advanced guide.
plz accept solution.
    Top Expert:
  • Audio Player... Master
  • 78,289 Answers
Have u adjusted the line input level for the mic? maybe it is turned off or way down
  • yadayada
    yadayada Mar 12, 2009
    there is a way to test the mic, u will need a digital volt meter has a Mili volt scale, touch it ro the mic connector jack on the positive and negatine ring, tap the mic, the meter should jump, if it doesn't then indeed the mic is defective, the other possiblity is a burned mic pre-amplifier in the amplifier input for the mic, it has to be one of those 2 things
    Genius:
  • 1,550 Answers
What is your model ?
    Brigadier General:
  • 3,614 Answers
Have you trey to test wih a different mic
  • micromaster
    micromaster Mar 08, 2009
    i seems that the problem was on he reciever mic input, better to call someone to check and inspect the unit
Philips SHG7980 microphone problem
Go to Tools...Options...Audio Settings and try choosing different choices for Microphone.
Jan 18, 2014 | Philips PC GAMING HEADSET BLACK/RED...
My at4033a/sm is about 6 years old and only used 2 or three times .plugged it in...there is no sound
I have two words for you...Phantom Power.
Electrete condenser mic's MUST have phantom power to operate. Look for "Phantom Power" button on your Jackie (surely means Mackie) and try it again BUT turn volume down before engaging phantom power or testing mic.
Feb 06, 2013 | Audio Technica Audio-Technica AT4033A...
Has a mist in motor
A miss or mist? If it is mist, possibly radiator hose, heater hose, oil sending unit. What kind of fluid is it? If it is a miss then first thing would be change the spark plugs if they haven't been changed in a while. If it keeps missing after that try pulling the spark plug wires one at a time with some spark plug wire pliers. If you pull one and it doesn't make a difference then that is the cylinder that isn't working. Put a spark plug in that wire and see if it is firing by grounding the base of spark plug and watching it. If it doesn't fire first try putting on a spark plug wire, if that doesn't fix it, you must have a bad coil pack. If you have spark when doing the test above then maybe an injector that isn't working. Please rate my answer so I am rewarded points for it.
Feb 01, 2012 | Cars & Trucks
I bought a soncm headphones sm-750mv but when I try to use the microphone it doesn't work. No manual.
This headset is pure bad. I have three and none of them worked. The manufacturer has no quality control or post production inspection. To fix the mic problem, open the earphone to which the mic is attached. You\'re likely to find that the mic wires are SHORTED together in a single piece of paper tape. Remove the tape, separate the wires and retape, assuming the tiny thin wires don\'t break in whic case you need to resolder the joins. Had the manufacturer any kind of QC, the faults would have been immediately obvious.
Jan 19, 2012 | Acer Aspire Computers & Internet
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
Remote control is messed up. car runs independently of control settings. won't stop. steering control doesn't respond. car worked fine when last used about two years ago. has been sitting in a...
Dear Jereed7,
Have you tried to change the batteries of the controller?
When you haven't used it for two years, then i would try that in the first place.
I hope I helped you with your problem.
With kind regards,
MisterN
Aug 10, 2011 | Nikko Toys
I left my Shure 87a in the car for a 2 week period back in the winter. didn't realize it was there..i notice now it doesn't seem to have the same clear, powerful sound coming out when i use...
The headline has two different mics listed... a Shure 87a and a Beta 98/S... not sure which you really have... Normally leaving the mic in the car should NOT have affeected it, although you haven't told us the environment such as humid or immersed in water, etc. On the chance it may have had condensation I would put it over a hot-air register for a few days to insure there is no residual condensation .. DO NOT place in an oven to try to speed this up. If there is condensation on the diaphram it needs to evaporate and vent slowly. Also you can look for corrosion on the plug contacts.
Jul 26, 2011 | Shure Beta 98/S Instrument Microphone...
Looked on 5 sites- inconclusive answers- sm 58 mic three posts on voice coil/ diaphragm, three wires leading to it. low imp use- connect which colors to which terminals? james
Try this.... Search google for: shure sm58 wiring diagram
In one of the results you will find diagram and colors in the upper left corner pix. If yours doesn't have those colors, congratulations, you have one of the counterfeit Shure mics that are being sold.
Jul 26, 2011 | Shure SM58 Professional Microphone
49 people viewed this question
 Grubhead
Grubhead
