Question about Hitachi 43FDX01B TV
How to get to the convergence screen on 43fdxo1b hitachi
4 Suggested Answers
SOURCE:
SOURCE: Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Posted on Mar 29, 2009
SOURCE: Hitachi 43FDXo1B
do you charge
Posted on Dec 28, 2010
TODDAS
  • 431 Answers
SOURCE: i have a hitachi 43fdxo1b
Go to the front where the speakers are and pull off panel, there will be a panel with some screws on it, Take it off, you will see your focus block. Top is g2 (screen) they will be marked bgr. B is on the top left, turn it counter clockwise.
Posted on Nov 10, 2011
I have a hitachi 43fdxo1b and sreen has a blue tinit on everything
Sep 11, 2011 | Hitachi 43FDX01B TV
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Wondering if hitachi telivision 43fdxo1b needs digital tuner or not also wondering what replacement remote i can get that will be fully functional with the tv
This unit does not have a digital tuner, only analog. The only way to get a remote that is fully functional is the one that was made for it to be available. Most Universal remotes only do basic functions unless they are made by the manufacture of the TV. Even then there is no guarantee.
Hope this helps,
Skyassoc
Jun 22, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Blurred picture on my 61" HD Hitachi
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 23, 2009 | Hitachi 46F510 46" Projection HDTV
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Try to adjust the red and then the blue convergence.
They have put together a kit for the Hitachi TV sets.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 43FDXo1B
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Jun 16, 2008 | Hitachi 43FDX01B TV
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
17) Turn power OFF.
Jan 13, 2008 | Hitachi 43FDX01B TV
Double Color images and Convergence will not adjustment will not line up
The convergence IC`s board location are IK 04 & IK 05. Looking from the back of the TV they are mounted to a large finned aluminum heat sink on the right side of the chassis. The origional part (stk 392-110) can be substituted with an equivalent but higher powered IC (stk 392-180) , that is 180 watt instead of 110 watt chip. Do not use generic IC`s! Purchase origonal Sanyo chips only for best results. Replacement of the chips alone may not cure your problem if there are dammaged resistors caused by the origonal chips. Check the standing resistors on the opposite side of the heat sinks for proper value. RK42(2.2), RK46(1.5), RK58(3.3), RK52(1.8), RK50(2.2), RK54(1.5). All of these low ohm resistors are rated at 1 watt. If you encounter a bad resistor you must replace with the same exact value. Close is not good enough. This should fix your set. Do not buy a policy you have a good TV. Be sure to use a liberal dose of heat sink compound when insatlling the new chips, and clean off the old crusty stuff.
Nov 16, 2007 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
