Question about Maytag PAV2300 Top Load Washer
MAYTAG LEGACY TOP LOAD WON'T SPIN OUT UNTIL YOU TURN CONTROL DIAL
WILL NOT SPIN OUT. I MUST MANUALLY TURN TO ANOTHER SPIN CYCLE TO GET IT TO SPIN OUT?
    Genius:
  • 1,066 Answers
THIS SOUNDS LIKE A BAD TIMER SWITCH.
Posted on Mar 13, 2009
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
My washing machine does not spinand drain out all the water in the original cycle. If I reset the dial to spin, it will spin and drain the water properly. Do you know what I can do to fix it? Washing...
Because it will work when you manually set the timer to spin, I would say that the timer has gone bad and that it is not getting you to the spin cycle automatically as it should...
Replace the timer and your good...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Nov 27, 2010 | Maytag Legacy Series Top Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag top load washer model number MAV7757AWQ. It will not spin out ( water just sits ), until I manually move the timer to the spin cycle and restart. Is my timer bad ?
based on your description..the motor for the timer sounds like it is bad or one of the wires powering it came free of the motor terminal.. Does the dial spin after you start any wash setting? If not then I'd say your timer needs replacing.. Hope that helps
Aug 30, 2008 | Maytag MAV7600 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag legacy load spin cycle
It is your main bearing, I don't recommend doing it yourself. You will need a special spanner wrench that you'll use only once. To see an exploded view go to Sears Parts
Aug 07, 2007 | Maytag Legacy Top Load Washer
Maytag PAV2300 Top Load Washer Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
