Question about Sony Ericsson T303 Mobile Phone (Shadow Black)
T-Mobile Shadow Water Damage
It fell into dog's water bowl. Tripped the warranty void. Can I reset this myself? So I can use my phone again.
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
My shadow fell in water screen first for about 4 seconds. i just turned it off and its been about 3 weeks since ive used it. it turns on but the screen dosent show anything. is it still fixable?
Posted on Mar 12, 2010
What can i do if my iphone is wet
Pray.
Some people claim you can bury the phone in a bowl of rice to draw out the moisture. You have to leave it in the rice for several days.
There is a company that makes a bag that is supposed to be able to do the same thing.
I doubt any of these attempts will be successful.
Water and electronics do not mix.
Depending on your warranty, you can see if the place you got your phone from can help. Water voids most warranties unless you pay extra.
Best thing is prevention with a water resistant or water proof case.
Aug 12, 2014 | Cell Phones
Phone fell in water
If it's at the point where the screen isn't working properly, it's dead. If you have some kind of extended warranty, it may cover it, but there's no real way to bring it back from being water damaged, unfortunately.
Jan 25, 2014 | Samsung Galaxy S GTI9000 Smartphone
What to do if the celfone fell in the water?
Take the battery out immediately and put your phone into a container of rice for the rest of the day. Make sure you do not power it back on for at least 24 hours. Because of it coming into contact with water, your warranty is most likely void now.
Mar 01, 2011 | Nokia Cell Phones
My mobile is damage by water how can i solve this problem
Get the Phone Out of the water. Do NOT power it on.
This may sound too obvious a step but a few extra seconds that your phone spends in water can reduce whatever chances you had of saving your phone.
If however your phone has spent more than a few minutes in water try removing the battery when the whole gadget is under water itself .
Powering up the phone when it is wet causes the maximum damage to your phone.
2 Remove the battery and SIM card
Water + battery is a bad combination for your phone. Remove the battery as soon as possible. SIM card too must be removed immediately as water on SIM cards may erase all your contacts stored in the SIM.
3 Dry the phone as much as possible
Try and pat dry the phone, the battery and the SIM card. Using a paper towel is advisable for removing water quickly.
4 Metciulously Disassemble the phone completely
This is one of the most important steps on your phone's path to recovery. If possible take your phone to a local mobile phone servicing shop and ask him/her top disassemble the phone completely for you. Make sure the circuits are not powered up by the shopkeeper.
If you are worried that disassembling the phone will make your warranty/guarantee void you need to know that phones come with Water Damage indicators which change colors with the slightest hint of water. No phone warranty covers water damage.
5 Dry all the phone components with a dessicant
After disassembling the phone immerse each component in a bowl of uncooked rice / silica gel packs. These dessicants absorb water effectively and draw out water from all nooks and corners of your phone. Heating / Vaporising the water is a bad idea cause that would leave salts on your phone's circuitry and cause corrosion and eventual death of your phone. Hence drying with uncooked rice/silica gels where water is removed by absorption is the best option. Leave it there for a couple of days.
6 Show patience and let every component lie under a table lamp for a couple of days
Now your phone is almost on its way to complete recovery provided you show Adequate patience. You may keep the bowl of rice under a table lamp for this duration . Changing the rice /silica gels though not a mandatory step, can be pretty effective and useful.
7 Assemble , Pray and Switch on!
Jul 14, 2010 | Nokia 1661 Cell Phone
My motorokr E6 fell in water after that it just gets on and shows the motorola sceen again it gets switched off the touch screen is not working please help me to solve this problem should i give to a...
before going to a service center try this....remove the battery and place only the phone with the back off into a container of either dry rice or dry oatmeal for at least 12 hrs or more...this should **** out ALL the moist. in ur phone....and if that dont work take it to a service center but you more then likley will have to pay for any cost to repair the phone even if its under warranty becuz any device with water damage voids the warranty...and they can tell if there was any water damage by checking the white round stick with red "x"s on it that is located behind r battery on ur phone...if the red "x"s have disappered...there has been water damage
Apr 18, 2010 | Motorola Mobility MOTOROKR E6
LG Vu phone fell in water and touch screen is not working.
Really your only option is to get a different phone. Since there is water damage it voids your warranty so you would have to turn to insurance. If you don't have insurance you may be able to do an upgrade or you would have to buy one outright. If you can't do that than you can get a prepaid phone and put you sim in that and it will work.
Mar 14, 2010 | LG Vu CU920 Cellular Phone
My portable hd fell into the dogs water bowl
Wow! I would need clairfication on this Can you tell me what is the chief complaint here, what do you mean it fell to the dogs?
Apr 24, 2009 | Western Digital My Book Essential Edition...
Bootloader usb init
Cell is damaged due to water, try resetting device first . If that doe'nt work you will need to exchange it if you have insurance, warranty voids with water damage!
Sep 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Phone dropped in soda
Well you know now that the warranty is void, so you should take the phone to a mobile service center and have them service it to try and have it working for you again......but most water/liuid damaged phones are like a 50/50 chance of working again.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
Water damage
if u have hotair gun so make hit treetment , use liquied flux and at first heat cobba ic thane check if problem will stil there heat flash and cpu
Aug 10, 2007 | Sony Ericsson W700i Cellular Phone
Sony Ericsson T303 Mobile Phone (Shadow Black) Logo
199 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
