Question about Kenmore 24032\24036 Top Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Kenmore elite calypso top loading washer....stops in the middle of
rinsing...leaves dirty water at the bottom of washer...and some
clothes stuck underneath the agitator...
  • 107 Answers
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Posted on Mar 14, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
I have a kenmore calypso elite washer. It stopped in the middle of a wash and displayed the message "Ld". I assumed that meant that the load was off balance. So I redistributed the clothes and...
lean washer back remove bottom cover have towels handy remove bottom cover on pump (if it has them) clean pump..if it doesn't best replace pump older pumps had spines that would strip out so pump would pump out the water
Sep 07, 2008 | Washing Machines
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
312 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
