Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have the same problem .i took apart the inside of
I have the same problem i took apart the inside of freezer found alot of ice i defrosted it and ran some warm water down the tube and it worked for a week and froze up again any ideas ty very much!!! evap freezes up
Check out this thread. It seems running a copper wire down the drain pipe will keep it from freezing. Seems to be a common problem and an efficient and easy to do fix.
http://www.diyprojects.info/bb/ftopic79524.html
Posted on Mar 08, 2009
I have a Kenmore Elite Refrigerator that has ER 1F on the display. Where can I find a manual with error codes or can you tell me what this means?
Hello Ken;
My name is Peter. I am a retired field service refrigeration technician.
The 1F code means there is a communication problem between the control board and the freezer fan.
Your freezer fan my have failed or it my be blocked by ice build-up.
So, It is one of these parts:
1.) Freezer fan motor
2.) Defrost heater
3.) Defrost timer.
You did not provide a model number so I can not provide you with parts numbers.
Although, I am retired, I do maintain a small customer base. If you live near Glen Burnie, MD, call me 443-306-1362
Dec 15, 2014 | Kenmore Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Freezer not maintaining it's temperature
make sure you melted accumlated ice and also the thermostat should be replaced by a new one
Apr 02, 2012 | KitchenAid Refrigerators
Freezer stopped freezing. The Freezer had alot of thing in it, once i took the stuff out he fan came on... Also, cant tell how the controls work... they are dials that say colder / Warmer with numbers....
The freezer not freezing can be 1 of 2 problems, the first being a defrost issue. If the defrost timer or defrost thermostat are bad they will not activate the defrost heater in order to keep ice from building up on the evaporator coils. In order to find out if this is your problem, remove the panel off of the inside of the freezer to expose the evaporator coils. If there is a lot of ice build up, this is your problem. The second problem will be that the compressor is low or out of freon. You will know if this is your problem if the evaporator coils are only partially frosting, there will be NO ice on the coils if this is your issue. This problem can only be repaired by a certified technician. If it ends up being just a defrost problem you can order the parts to repair it at Reliable Parts, using your model number to look up the parts. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 22, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Frigidaire side by side, water leaking onto bottom of freezer
If you looked at the back section of the freezer (inside) and found ice then you need to completely defrost the fridge freezer. What you are describing is a frozen evaporator and the freezer needs airflow to work properly. If the unit starts behaving normally after defrosting then you need to monitor it closely as they will normally start playing up again after 2-3 weeks. If it does fail again then you probably have a defrost problem normally the defrost heater but can also be the defrost timer o defrost sensor. If it fails to reach temp then I would suggest contacting a decent repair guy who should be able to diagnose which one within a reasonable time. I would recommend defrosting first though because the same symptoms can happen when a door is left ajar. Hope the above is of some help.
Sep 14, 2007 | Refrigerators
Ge Side by Side Freezer defrost
just check continuity thro the heater but these heaters are reliable.there should also be a thermal cut-out in series with the heater and check this as well.
Apr 18, 2007 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
