Question about Home
"Can you replace only the toilet bowl and use the existing tank"
I want to change to an elongated toilet bowl. Do I have to buy both pieces or can I use the old tank? No problem with toilet just would rather an elongated.
    Problem Solver:
  • 17 Answers
Its usually better to buy the set, but if you don't want too that's fine. As long as the water capacity of your old tank is what the new bowl requires. If you look at the set at the store, it will usually tell you the water capacity and specs of the new bowl. Although most bowls use the same holes and bolts to combine the tank and bowl, make sure the old tank will fit on the new bowl you selected.
Posted on Mar 08, 2009
Water is leaking from the tank to the bowl.
I've had this happen before. Mine was a bad seal between the tank and the bowl. I had to replace that stopper and the gasket underneath it between the tank and the bowl. It's not very complicated or dangerous, but you will have to remove the tank to do it. Have plenty of towels ready and plan for a place to sit the tank in (maybe your bathtub) while you are working.
Oct 21, 2012 | Sterling 402315-96 Biscuit Windham...
Jacuzzi espree toilet leaking water from bowl without flushing. water on floor in front.
Hi!Maybe the problem of your toilet is in the mechanism inside the tank that's why its always leaking.Kindly check the tanks fittings of your toilet and replace it if necessary.
Sep 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
My Crane toilet is slowly leaking into the bowl. It is not the flapper (which I replaced) and doesn't seem to be from high water pressure. Could it be the seal?
Check your over flow pipe in the tank to see if you need to lower the water level amount in the tank. If thats not it, it could be the seal thats under your flapper between the tank and base. Simple fix just alittle time consuming
Sep 24, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Need a tank to bowl gasket for pegasus toilet
homedepot or lowes will have this part just go an ask some one in plumbing
Aug 18, 2010 | Pegasus Technologies Elongated 2 Piece...
I need a tank LID for the 270 Caravelle dual flush toilet. Where can I get one fast? A customer broke the lid in a thousand pieces and we need a replacement ASAP.
Toilet seats are standard and fully interchangable. You should be able to pick one up at your local hardware store. The only thing you need to know is if you have a round or elongated bowl.
Sep 18, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
1,041 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
