Question about Dell Latitude C600 Refurbished LCD Display Bezel - 0F765 (RB) CD-ROM Drive
When power cord is unplugged laptop has no power.
  • 948 Answers
Your battery is dead. If you are using the correct power "brick" that your computer requires and it will not charge the battery you need a new battery.
Posted on Mar 08, 2009
Gateway laptop wont turn on what can i do?
Unplug it, and remove the battery. Hold the power button down for 30 seconds. Then examine the block on the power cord to make sure that the cords are plugged in all the way. Put it all back together, and if your power cord is okay, it should fire right up. If it doesn't, your power cord may be bad.
Dec 22, 2014 | Computers & Internet
Computer charges but doesnt want to start up
Remove battery
unplug power cord from laptop
press and hold power button for a least one minute while power cord and battery are removed
insert power cord only
turn on laptop
laptop should turn on without battery installed
if it does not turn on you probably have some motherboard issues
then install battery if it still does not turn ...and try to turn on
it still may turn on...I have seen stranger things happen with computers
you may also want to try another power cord if you have an extra...the power cord may not be allowing enough power to travel thru cord
Feb 15, 2014 | Toshiba Satellite Computers & Internet
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont would run for a short while on the battery when...
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
Unit will not power up G4 laptop will not power up when plugged into power cord or at any otheer time
it might be your power cord kindly double check this is very common problem because when you unplug the power cord be sure that you hold it not in cord.
Aug 28, 2009 | Computers & Internet
Computers & Internet Logo
Alun Cox
