Question about Dell Computers & Internet
Hi,I just want to disconnect Ethernet and run with Wireless I have a Billion Myguard 7202G router which worked fine with Ethernet and has worked wirelessly beforebut shifted and cant remember how to set it up and where & what to look for,thanks in advance !!
  • 281 Answers
Open the web browser and type 192.168.1.254 in the browser’s
address box. this number is the default IP address for this router.
A username and password window will appear. username and pass should be admin.
If you change the password and dont remember it. Look for a restart button on the back of the router. This will reset it back to default.
When you manage to login look for WAN and WEP setings
Posted on Mar 08, 2009
Billion 400g
Your repeater probably worked as it was supposed to but because you don't really understand the technology, users like yourself plug gadgets in, push the limits to the maximum and then wonder why it fails.
The best way to extend your network is to run an ethernet cable to a repeater.
Trying to extend a weak wireless signal via wireless will almost always be doomed to failure.
Mar 20, 2014 | Computers & Internet
Instructions on how to connect my laptop to my adsl modem wirelessly.i have a 5200g billion router which is connected to my router via ethernet cable.i have a lenovo laptop with bluetooth.
Billion's BiPAC 5200G R4 is an economical ADSL2+ Firewall Router with 802.11g Wireless AP ideally designed for home and SOHO users to enjoy rich firewall security, mobility, and faster speed when using ADSL Internet connection.enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without reconfiguring your laptop with wifi.
Jul 13, 2011 | Computers & Internet
Wireless light is on but when I bring in my laptop it doesn't find my network. Just quit working. ??
Turn the router off, and unplug the AC power.
Turn the router on, and wait until the lamps show that it's fully ready.
Be sure that you have _not_ disabled your laptop's wireless networking.
On your laptop, click to "view available networks".
Does the router's "SSID" show up in the output?
Connect an Ethernet cable between the Ethernet-port on the router and the Ethernet-adapter on your laptop.
Click Start
Click Run
Type 'cmd' and press ENTER.
In the "black" window, enter 'IPCONFIG'.
Find the line showing the IP-address of the "Gateway", probably something like '192.168.xxx.yyy'.
Start your web-browser, and enter: http://192.168.xxx.yyy
to connect to the router's web-interface.
Click to run the "Wireless Network Setup Wizard".
The router should restart.
Disconnect the Ethernet cable.
Repeat the "Show available wireless networks".
Or, try some other wireless-ready laptop or wireless-ready iPod Touch, to see if these devices can "see" your router's SSID.
Oct 21, 2009 | Linksys Wireless-N WRT150N Router
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Wireless Internet router (home) Security
Unsecured means that you have not set any passwords or keys to lock your wireless connection. This is not a good practice. And yes, if the connection is unsecured, then others will be able to use it without any problems.
Do this if you are comfortable:
1) Go to Internet Explorer
2) Type http://192.168.1.1 (If that does not work, then try http://192.168.1.254)
3) Type the Username and password (both "admin")
4) Look for a Wireless tab
5) Look for Security and then look for WEP encryption.
6) Enable 64-Bit WEP encryption and type a key there. Save the settings.
7) Now when you try to connect to your connection, it will ask you for a key, put the same key as you had put in the router.
Please keep in mind to wire your laptop before doing these steps. Otherwise, you may be disconnected.
May 13, 2009 | Dell Dimension 3100 PC Desktop
Cant connect to my wirelessmodem
Try running the cd that came with the router again, since you reinstalled windows, the configurations for the router have been lost. If this doesn't help let us know and we'll work on it from there.. good luck!
Mar 14, 2009 | Dell Dimension 3100 PC Desktop
Wireless connection set up
Are you trying to hook up the laptop wirelessly to the pc? because then the pc would need to have a wireless card as well....sounds like I need more info, but if you are trying to do what I think you are, you should just get a wireless router instead, hook the pc tower directly to it via ethernet cable, and then setup the laptop to connect to the router. The router would hook to your dsl or cable router....what service do you have?
Mar 10, 2009 | Dell Dimension 3100 PC Desktop
Belkin wireless adapter
Sometimes wireless phones will interfere with the signals. If the router or PC is anywhere near a phone, it might have a problem. I have one wireless network card that gives me fits like that. I have yet to get a PC working with it. I have other wireless cards that work fine. I also switched to 5GHz phones, which helped my old laptop. Check to make sure there's not a conflict with the encryption used by either the dell or the router.
Jan 19, 2009 | Dell Dimension 2400 PC Desktop
Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Jun 03, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
56 people viewed this question
Alun Cox
