Home | Asrock | K8Upgrade-VM800 Motherboard | Acer monitor does not...
Asrock K8Upgrade-VM800 Motherboard
Problem for Asrock K8Upgrade-VM800 Motherboard
Acer monitor does not get signal every time
By jottharris on Mar 08, 2009
Acer monitor will only accept a video signal on every other start up. Once up, it's fine until the next power down and then system needs to restarted twice before it boots.
I'm running an AMD K8Upgrade-VM800on an ASRock MB. I have tested the power supply, replaced the HD, Disabled onboard video and added a GeForce2 MX video card.
Same problem. I'm hestitant to flash the bios, but I suspect it to be either the Bios or the processor.
I am completely stumped.
Help!
Thx
JT
Comments:
Mar 08, 2009
- The monitor is an ACER LCD model X163W. I also plugged in an old Viewsonic crt and the same thing happened.
There does not appear to be newer drivers, or I can't find them. Grrr.
Thanks
Mar 08, 2009
- Sorry, I forget the MB info.
The Motherboard is an AsRock K8Upgrade-VM800 Socket 754 with an AMD Sempron 2600+ processor.
Integrated UniChrome Pro 3D Graphics in VIA® K8M800 chipset
Mar 08, 2009
- Sorry, I meant to ask for the newest drivers for the onboard UniChrome Pro 3D/2D Graphics controler.
As it is now, with the GeForce Graphics Card installed, the system is doing exactly what it was when the onboard configs were active.
Start it up, turn it off or try a restart and the monitor goes black and then displays "NO SIGNAL"
Then I have to Power off, using the rear switch, power back on once or twice for the system and monitor to load it to normal.
Can Anyone tell me how to fix this? Please. My sanity is at stake.
Clarification Request
Posted by DickCanFixIt on Mar 08, 2009
The processor has nothing to do with your video signal. So let's rule that out. The GeForce 2 series has hardware that is far older than the motherboard you are using. Your onboard video is probably a lot better. Which motherboard are you using? I'm leaning towards a bios problem, have you tried the default bios settings for compatibility? Make sure you write down your current settings before you change anything.
Solution #1
posted on Mar 08, 2009
Somewhat Helpful)
gymowner
Rank: Wiz
Rating: 85%, 233 votes
If anything try updating the video card drivers. That's what it sounds like, or the monitor is going. The next time the monitor fails to start, just unplug from the input and put back in. If it starts you are looking at a bad power booster on the board. You can also try pluging in another monitor or try that monitor on a different machine. This way you can eliminate which is bad. I had flat panels and crt's go on me and they usually start by this symptom. It shouldn't be the BIOS, if it's been working right along, same with the processor, it either works or doesn't, it's a monitor scenario.
Comments:
Mar 08, 2009
- http://www.nvidia.com/page/geforce2mx.html
Here is a link for your drivers, always shut off your virus software when installing, just disconnect from the net when you do, good luck
Was this helpful?
Yes
No
Popular Solutions for Asrock K8Upgrade-VM800
Questions and Unsolved Problems for Asrock K8Upgrade-VM800
Do you recommend Asrock K8Upgrade-VM800 Motherboard?
Answer
Answer
Have a Brother MFC 7420 multi function printer/copier. Keep receiving screen message "Back... (More)
Answer
my pc is showing IBM emended hardware remove
Answer
bilader benim EP-8KMM3I-X seri anakartım var ben bunun ses ve vga driver... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Asrock K8Upgrade-VM800...:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14047
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
