Now here's a potentially dumb question: When you guys work on parts of
your bikes that require removing the wheels, how do you prop the bikes
up? Center stand? Or do you need a special stand ? Is there any FAQ
on the basic bike fixing procedures (changing brake pads, adjusting
chains, etc?)
Hmmm, why do I get the distinct feeling I'm going to be flamed for
this...
Serge
(need to get the libraries so I can get the compiler to compile the help
pages to read the manual to figure out how to make a newsgroup-specific
.sig on my newsreader).
Rating: 0%, 0 votes
\removal of any wheel tips the bike the other way - so you can remove
\any wheel temporarily with min hassle.
This is the most annoying design cockup on the GS500. Take off the front wheel
and the front end crashes to the floor
Prop it up by sticking you helmet under the exhausts.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
board
Own: 84 VF500F -needs name Fix: 86 VF500F(G), 84 YX600 Radian
72 CL175 -needs grave 82 Vision 550 (UGH!)
Momma always said "Life is like a box of chocolates,
by the time you get there, someone else has eaten the pecan clusters"
Rating: 0%, 0 votes
Emphasis on the use of a STEEL milk crate. The plastic ones are,
indeed, very sturdy, but may collapse after a few minutes.
*Hypothetical Situation* (are there any other kinds?) You put your
dirt bike up on a plastic milk crate, and then you walk a short
distance to relieve yourself (ahem). You hear a large crash and run
back to your bike to find out that the crate has collapsed and the
bike has now made a wonderful dent in the side of your truck and
snapped the front brake lever clean off.
Pick up bike. Scream and yell. Stomp feet. Remember to zip up your
pants.
Dave
Dave Petke DoD # 1615
Kennett Square, PA
Rating: 0%, 0 votes
On many bikes with center stands, the balance is set up so that
But never back your truck into the bike when the rear wheel is off.
And never, never do this when you have the swing arm off, too.
So that the bike falls over on its side, and you have to have your
wife (who is fortunately pretty strong, and has a helpful attitude)
help to bodily pick up the bike and set it back on the center stand.
Not that this ever happened to me. Nope. No way.
Many folks also use a milk crate (steel) to support underneath while
working, and there are are special stands available, as well.
1959 BMW R50 Jim Rozen
1969 BMW R60US (JRR0 @ watson.ibm.com)
1975 BMW R75/6 (The "new" one)
Rating: 0%, 0 votes
& Now here's a potentially dumb question: When you guys work on parts of
& your bikes that require removing the wheels, how do you prop the bikes
& up? Center stand? Or do you need a special stand ? Is there any FAQ
& on the basic bike fixing procedures (changing brake pads, adjusting
& chains, etc?)
Always tell us what bike you are working on.
For a dirt bike just lift it up and sit the skidplate on a milk crate.
For a bike with a center stand just put a jack under the front of the
engine to get the front wheel up (put a board between the jack and the
motor).
For a sport bike with no center stand just spend $300 for front and
rear work stands, then machine a custom adapter to get the front stand
to work.
Frank Ball 1UR-M (707) 794-4168 work
Hewlett Packard (707) 794-4848 fax (707) 538-3693 home
1212 Valley House Drive Yamaha XT350 YZF600R Seca_750 Kawasaki KDX200
Rohnert Park CA 94928-4999 KC6WUG, AMA, DoD #7566, NMLRA, I'm the NRA.
Rating: 0%, 0 votes
I use a swingarm stand and a number of large flat bricks. I put the
bike on the stand, then grab the front wheel and lift the bike while
a helper shoves the stack of bricks (with a piece of soft wood over the top)
under the engine/headers. This is a very stable configuration; much better
than using a center stand and shoving a jack under the engine.
Obviously this won't work with a Leadwing or a Hardley, but a light
bike such as your GS is easy to lift even for a scrawny geek like me.
An adjustable swingarm stand works with a variety of swingarms, which I
appreciate as my ratio of center-stand-challenged to over-center-stand-onated
bikes is 5:1
Yeah, it's called the SuperFAQ. Just ask for it by name.
What you'll need in addition to the SuperFAQ is the shop manual for the bike.
That you can buy from a dealer or via mailorder.
Stan
Post a New problem for Harley Davidson Harley-Davidson
Email this problem
Can you Help with these Phones problems?
no fire
turn signals
04 1200 Sportster - backfires -...
motorcycle bag install
check engine light
