Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
My dishwasher will not start. I have checked the
My dishwasher will not start. I have checked the breaker but it is not the breaker. we checked the wiring but it is ok. I am at a loss. What else could it be. No lights come on. Nothing. I have had it for three years.
  • kmoore270295 Mar 08, 2009
    frigidaire model FDB1050REB2
  • Anonymous Mar 16, 2009
    I just istalled my dishwasher. After installation we tested it to make sure everything would run...it did then it stopped in the middle of a cycle and we cannot get it to come back on. The dishwasher is hooked up wtih the garbage disposal and we have power to the garbage disposal but nothing on the dishwasher. It is brand new!
  • Frigidaire Master
  • 8,220 Answers
  • Interesting question Post your model number to any of these fine forums for
    a simple answer that will save you lots of money:
    http://appliancejunk.com/forums/index.php?referredby=858
    http://forum.appliancepartspros.com/
    http://applianceguru.com/
Posted on Mar 08, 2009
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
Dishwasher will not run
Just try unplugging and see if that resets the control panel. Sometimes that will do it. Good luck
Dec 16, 2017 | KitchenAid Dishwashers
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Hi everytime we use the dishwasher it blows the circuit breaker now we cant even trip the breaker to use the dishwasher and ideas ?
disconnect dishwasher and put wire nuts on lines try to turn on breaker if goes on than u have a short in the wiring of the dishwasher -open panel and check connections if look good than start testing lined and components with an ohm meter for short ----if breaker doesnt go on check wire feed for short
Jun 28, 2011 | Asko 1385 Dishwasher
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
Dishwasher will not turn on. Last night I started
You need to measure with a voltmeter for 115 Volts at the electrical box under the washer front. Breakers can fail, yet look ok. This will check the breaker output and all of the wiring in between. There may also be a local circuit breaker that tripped.
Aug 18, 2009 | Dishwashers
Dishwasher will not start after change in electric meter outside. Dishwasher "popped " when it was started Check all circut breakers etc- all fine
if you have 120volts at plug,chk for a breaker inside unit and again voltage inside unit at terms on cord,then if so chk motor for a breaker on the motor,some have built-in breakers,then check door interlock switch for continuity and proper operation, then if electonically controlled check for a fuse and burns on the circuit,you may have suffered a voltage spike,and do it soon,the power supplier may be liable if you can prove he disconnected the neutral and you only had 240volts,this could be a cause also as it becomes a voltage divider circuit w/o the neutral connected
Jul 29, 2009 | Dishwashers
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
236 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
