Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
I hooked up a Jacuzzi bathtub and pump won't stay on
It is an Espree 6036 I ran 12/2 wire to a gfci plug in 15amp the pump starts runs for 1 or two minutes if I hold button down (magic touch switch) will not stay on if I just push button. If I push button half way when it goes off I can push it just a little further and it will run a few more secounds when it goes off it will come back on in just a few secounds if I push the button again.
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Posted on May 26, 2010
    Problem Solver:
  • 6 Answers
Faulty switch
Posted on Mar 22, 2009
Removal of air swicth model U640
It sounds like the machine uses security-type fasteners, which require special screw bits. You may be able to remove the screws with one of these security bits, such as those sold by Harbor Freight.
Apr 15, 2014 | Jacuzzi U640958 Espree 6036 Drop In,...
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Jan 23, 2013 | Jacuzzi Home
I have the espree 536 jacuzzi tub. which heater is required for this unit. i ordered the s750000 but it is the wrong one
you will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
Jan 16, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
I have a whirlpool jacuzzi tub. I wired to diagram but when tub is full and I turn on jets it trips a breaker. Not GFCI outlet but breaker panel breaker.
Sounds like you may not have a ground on the motor of the pump or a grounded outlet?
check the wiring on the motor on the cord to make sure there are no wires improperly attached inside the motor housing.
Jan 07, 2011 | Jacuzzi Amiga, Soaking Bathtub with...
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a Jacuzzi Aero Select Tub, everytime i
Run an extension cord from another gfci and see if it works. If so, you could have a faulty gfci or issues internally to the motor. Also, if the "home run" for the tub is wired into a sub-panel and the grounds and neutrals are not isolated it could cause problems with a gfci as well.
Hope this helps!
Feb 02, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
Faucet placement on Jacuzzi 6036
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like. a1da3ad.png
Jan 08, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi jets & heater,won't stay running,need electrical schemati
Actually you can ground them to the copper pipe...any piece of metal material that comes in contact with the earth...hence the word water supply line or if you ran conduit..and a receptacle box (metal...) you could ground it to that....'
I hope this helps...good luck...thanks for rating my effort...the Fang.
Mar 28, 2009 | Jacuzzi Home
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
1,993 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
