Question about SanDisk Sansa Clip MP3 Player
Menu screen does not turn on no display screen
  • Anonymous Mar 08, 2009
    like when i ever i have it pulged it will turn on but then when i unplug it just turns off what can i do to fix it?
  • 8,596 Answers
Make sure the hold/lock has not been engaged first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    Turn off On Screen Display?
    Hey,
    unless you have such a option in the on screen menus, please go over all of them, then no, althought it should atleast my monitors do goto power safe mode ones theres no signal.
    Thanks,
    Ekse
    Sep 06, 2008 | Coby Computers & Internet
    No remote to turn off display
    Hello
    If there is a "Menu" button, on the front panel of the TV, press it, surf through its menu options [display options], and turn OFF the dispay. If there is no Menu button at its front pane. you cant turn the on screen display option without a remote control.
    Feb 27, 2012 | Protron PLTV-32 Television
    Hi i have accidently deleted the voice navigation from my navman 550 sat nav and cant get it back ihave tried reset can you help
    Is it Possible you have turned off the volume?
    Here is how to check the volume setting:
    From the Main Menu screen, tap Preferences.
    The Preferences screen will display.
    2. From the Preferences screen, tap More Preferences.
    The second Preferences screen will display.
    3. On the second Preferences screen, tap Hardware.
    The Hardware screen will display.
    4. From the Hardware screen, tap Volume.
    The Volume screen will display.
    5. To increase volume, move the Volume Level slider towards High; to decrease volume,
    move the Volume Level slider towards Low.
    • Tap Test to test the volume.
    6. Tap Save.
    The Main Menu screen will display.
    Jun 06, 2011 | GPS
    How do i turn off the message keypad noise that happens when im typing a text message?
    Sounds
    • To set volume for media and videos, from the home
    screen, touch Menu > Settings > Sound &
    display > Media volume.
    • To play tones when using the dial pad, from the
    home screen, touch Menu > Settings > Sound
    & display > Audible touch tones.
    • To play sound on a screen selection, from the home
    display > Audible selection.
    Feb 22, 2011 | Motorola Mobility Defy Cell Phone
    Sony VPL-CS5 menu will not display
    Give input signal to the projector and see that if the menu appears or not on the screen.
    if menu comes on the screen then put the backgroung color to blue, instaed of black.
    if nothing comes on the screen, then the LCD panels are faulty.
    Viren
    RAVE SERVICES
    Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
    I ccannot find a screen display menue. I have seen it before. My screen needs to be changed
    Tom Tom can do lots to things but they are not all shown on the Main Menu Screen initially. This is done to save space on the screen. If you are able to get to the Main Menu, Tap the change preferences Icon. You should then see an option called "show all menu items" On this menu, you should find all the options available including one called "Turn Off Map Display" Tap this choice....You should then be able to select what you want your map display to do. Thanks for using Fixya.com!
    Jan 27, 2009 | Tomtom ONE GPS Receiver
    Volume and menu does not display
    I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
    Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    Number display always on
    if you can access the menu on your remote or the front of the set you can turn this function off. somewhere in the menu will be something called OSD( on screen display) and you can turn it off. sometimes the menu can be accessed by pushing the channel up and down buttons on the front of the set at the same time.
    Jan 11, 2008 | Sanyo DS27510 27" TV
    SanDisk Sansa Clip MP3 Player Logo
    79 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
