Question about Eureka 402A Bagless Upright Vacuum
I would like to disassemble my eureka altima to clean brushes
How do I take apart the eureka altima to try to clean the brushes.
  • 21 Answers
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Posted on Jul 23, 2009
  • 8,220 Answers
Most of the newer models have some screws mounted atop the brush housing. you twist them a quarter turn and lower the handle and body to the floor. Lift up the cover and you can now access the belt and brush compartment.
Posted on Mar 08, 2009
How can I disassemble the Eureka Altima Brush Roll (#60844-7) for cleaning? Thank you, Jerry in Irving, TX
You can remove the two screws in the top cover above the roller. Then lift off the top cover exposing the roller. You can then pull the roller out, and clean out the cradles that hold the end caps. The square end caps can also be pulled off the bearings at the ends of the rollers. I had a lot of stuff wrapped around mine creating a lot of drag, but the bearings were just fine once everything got cleaned out. Just remember which end cap is which, cause they're different for each end.
Oct 05, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
Eureka Altima - before I can get one room vacuumed the belt breaks. Why?
If the belt is breaking that quickly, there is one very prominent culprit that could be causing the problem. Check to see that the beater brush, the roller brush that the belt is supposed to drive, is turning freely on the unit. Remove the brush and clean as best you can. Add some WD40 at both ends of the beater brush by the hard rubber holders and turn the brush by hand to work it into the joint. Reassemble and be sure the belt is put on so the brush turns in the proper direction. Paul
Oct 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Is the roller brush supposed to turn when the power is on?? the sucktion is on but the brush doesnt roll
That means that you need to replace the belt which turns the roller brush. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Jan 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka IMA Vacuum - brush not turning
Your belt is probably stretched or broken. Here is a link to the belts you need and to the manual which has instructions:
Eureka Altima Replacement Belts
Owner's Manual
Nov 24, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you replace the belt
Check for a pair of screws at the outer edge of the brush housing area. On this unit I believe the unscrew form above. Then look for any others on the bottom plate below the the brush. Belts can break or burn thru. If your s has burned, clean the burned rubber from the motor shaft before replacing. Spin the brush roll, if it rolls smoothly remove it , place the belt over the motor shaft, then onto the brush and use the brush to pull into place.Check for hair and thread buildup at the end caps of the brush. The nylon caps pop off for cleaning.
Sep 06, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you clean/take apart the roller brush ends. One end turns easily, but the belt end is somewhat harder to turn.
one end is usually fixed the other is not :pull staight out on the end with the belt. to put back :put on belt side first; lock in place with a little effort and put in other side.
Jun 20, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Nov 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 402A Bagless Upright Vacuum Logo
604 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
