Question about iSonic SNAPBOX DV566 Digital Camera
Wont turn on
Some times my camera turns on when I open the flap thing up but it takes like 1 in 100 tries until it turns on. I know it will charge and stuff but it will not turn on when i open it. I have the Isonic Snapbox DV566.
    Problem Solver:
  • 7 Answers
Its not getting enough juice from the battery. Get a new battery. You can only re-charge a battery so many times. Many times people ruin the battery by not fully charging and draining a battery. The battery that came with this cam has a memory. Get a new battery.
Posted on Dec 20, 2009
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
My camera wont even turn on
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 01, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Camera wont turn on.
Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Oct 31, 2007 | HP Photosmart M425 Digital Camera
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
Camera just wont turn on...help please
I opened up mine today and found out that all you needed to do was put the plastic gear back into place and it's A ok. Open up the camera and when you're facing the front, check the little plastic compartment on the top right to see if the gears are in place. I fixed it and everything is A ok now. :)
Nov 19, 2006 | Casio Exilim EX-S600 Digital Camera
My camera wont turn on
I had the same problem, here is how I fixed it: Make sure batteries are fully charged, Open the cover of memory compartment, the red LED is flashing, it means that there is a reading error. I reset the camera (under the output connection cover), took off the memory chip, and replaced with a spare one, then it powered on and prompt to date/time set up. Let me know if this works for you. John
Jul 29, 2006 | HP Photosmart 435 Digital Camera
iSonic SNAPBOX DV566 Digital Camera Logo
65 people viewed this question
Top iSonic Cameras Experts
BJ Russell
Jay Plesset
Tony Parsons
Tony Parsons
Are you an iSonic Camera Expert? Answer questions, earn points and help others
