Question about Frigidaire FRS23R4A Side by Side Refrigerator
Frigidaire Model # FRS23R4A - Not cooling
Refrigerator: Frigidaire Model # FRS23R4A side-by-side was purchased in 2002.
The lights are on, the fan is running, the compressor is not hot it is rather cool to the touch and there is not noise at all
Both the fridge and the freezer are not cooling. Is the problem with the compressor or something else. Thanks for the help
  • 3 more comments
  • machouicha Mar 10, 2009
    Hi Peyton,
    The fan next to the compressor is running. I pull out the relay/capacitor from the compressor, then put it back. Now I hear a buzzing every two minutes, this buzzing goes for 10 sec. then stop until the next two minutes.
    I have been told, one way to check it the relay is bad, is to pull out from the compressor and shake it, if there is any rattling, then it is bad, which I did, and indeed I hear some rattling. Now I am wondering how I can test if the compressor is good or bad. Any comments are welcomed. Thanks.
  • Anonymous Mar 29, 2009
    same thing to the ttttttt
  • muftah20002 Apr 10, 2009
    I have the same problem. It runs for 2 min then it stops just fan keeps on going. I checked the back, but there nothing i could notice? any help or should i throw it away?
  • machouicha May 22, 2009
    My Frigidaire Model # FRS23R4AW6 is not working.
    The fan next to the compressor is working.
    I replaced both the relay/capacitor but still the compressor is not starting.
    I did a ohm reading of the compressor, it looks good:
    C-S = 9.3
    C-R = 4.1
    S-R = 5.7
    Is there another test or check before I gave up on this frig? Thanks
  • peyton thompson
    peyton thompson May 11, 2010
    is the fan next to the compressor running? its possible there is something wrong with the compressor or hte starter for the compressor but if the fan that cools the compressor is not running then you may have a temp control messed up. let me know. Peyton
  • 410 Answers
Wihtout replacing the relay there really isnt any way to tell if its the compressor or the relay. the relay is veyr inexpensive in comparison to the compressor usually less than 70 bucks. and the best part is you can replace it yourself as opposed to paying a service company. this is the part number 218721113 and it prices at 38 dollars thru
once you replace the part if the compressor starts you should be ok. if it doesnt start then you will need to call a service company to replae the compressor or look at replaing the refrig. if the unit is less than 5 years old it may be under warranty for the compressor so check into that first. if I can be of further assistance dont hesitate to ask. thanks Peyton
Posted on Mar 10, 2009
  • peyton thompson
    peyton thompson May 23, 2009
    I am assuming that you verified line voltage to your compressor so after replacing the relay and overload if the compressor will not start you have a bad compressor. the cost of repacing a compressor is generally prohibitive in comparison to replacing the refrig. sorry for the bad news.
How do i replace the evaporator fan on frigidaire FRS23R4A
Feb 21, 2012 | Frigidaire FRS26R4A Side by Side...
Model FRS23R4A - loud humming noise coming from inside freezer section at top behind the ice maker. What might this be?
Somebody hiding in your freezer? Na, I'm just kiddin! Sounds like an evap fan going bad on ya. Eventually you will need to replace the fan!
Thanks and please rate me!
Tips Provided by: Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Frigidaire FRS23R4A Side by Side...
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Fridge on the Fritz
sounds as if perhaps theres a fan in the freezer, copartment that is not spinning, circulating the cold air around, or if that fan is spinning you have adefost issue,not "self defrosting so the ice is building up preventing proper circulation
Nov 02, 2008 | Frigidaire FRS23R4A Side by Side...
Not Cooling or freezing.
you need to clean the evaporator coil under bottom off refrigerator. and check in the back of refrigerato to see if fan is runing. I not you need a replace it sam
Sep 25, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23R4A
no cool but copressor running
Jun 01, 2007 | Frigidaire FRS23R4A Side by Side...
could mean ice build-up on evaporator - buzzing could be fan jammed asgainst ice. remove back panel of freezer to check. this would usually affect fridge as well however
Apr 10, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
750 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
