Question about Microsoft Windows Vista Ultimate Edition
I have Windows Vista Ultimate, my computer was running slow, so I decided to reinstall the OS. It boots with no problem and goes as far as setting up your computer. Then a window pops up stating windows installation inaccessible, asks to make sure that it is accessible, but I have no idea how to do this, can anyone help. (Note: Windows XP Pro installs with no problem)
  • donaldhantzs Mar 09, 2009
    THANKS FOR TRYING CAJUN, BUT THE ONLY PLACE I CAN TYPE ANYTHING IN IS THE COMMAND PROMPT, AND IT WOULDNT TAKE, BUT CHECK THIS OUT, I HAVE A COPY OF XP PRO FROM MY DESK TOP AND IT LOADS FINE, BUT I CANNOT FOR SOME REASON HOOK TO INTERNET WITH IT, THEN I FOUND A FILE CALLED UNLOCKER, TURNS OUT FROM MY RESEARCH ITS A WORM, BUT HAVE HAD NO LUCK REMOVING IT. DO YOU HAVE ANY SUGGESTIONS? THX
    THANKS FOR THE HELP, YOUR THE BEST, I FOUND "UNLOCKER" PROGRAM THAT I DIDNT KNOW WAS ON MY COMPUTER, RESEACHED IT AND FOUND IT COULD BE A TROJAN OR WORM, UNINSTALLED IT, WIPED DRIVE WITH DISK WIPER PRO 4 AND REINSTALLED OS, WORKED GREAT, THANKS FOR YOUR HELP
Cenon i have ultimate, my computer was running slow,so i decided to rainstall the os
Posted on Mar 09, 2009
Pa duplicate
Posted on Mar 08, 2009
  • 741 Answers
Your missing the files that load the operating system. Put the vista disk back in, let it run and it will eventually ask if you want to setup or repair. Choose repair and then type "fixboot". That will fix your master boot record so the operating system can load.
  • Randall  Trahan
    Randall Trahan Mar 09, 2009
    And the plot thickends..
    On your first question: Yes, I know you only get the command prompt the "R" stands for "Recovery Console". Either "fixboot" or "fixmbr" is type there is a master boot record is corrupt and you can't boot.
    Second. Since you cannot hook up to the net then you can't get a copy of the anti-virus AVG. Its free and powerful. You're only option at this point is to do a system backup of all your favorite files, docs, favorites, email, etc. with Windows Backup. Then format your hard drive to wipe it clean. This will take care of the virus. Then reinstall everything...good luck let me know if you have any questions and let me know how it turns out.
Why is my OS is very very slow working???
Here's a few tips you can try to fix your slow startup problem. First of all you want to disable any programs that are in the startup menu that you do not absolutely need. There is no sense in waiting for programs to load that you don't use on a regular basis. Or if you are not sure which one is slowing your startup. You can disable them one at a time.
If that did not help, you can disable your Windows sidebar. You'll also want to remove any icons from your desktop that you do not absolutely need. The same goes for your task bar and quick start menu. All of these will slow down your boot time.
Check to make sure your anti virus program is not scanning at startup. Some programs are set to scan. When windows boots, by default. You will also want to do a full anti virus scan to make sure you don't have a worm or any other type of virus that is working in the background slowing your operations down.
The biggest reason for a slow boot time is a corrupt or damaged Registry. The registry will become corrupted from installing and uninstalling programs. Perhaps you have loaded programs onto your new Vista computer and were not compatible and then uninstall them. They leave behind files, which Windows tries to reference on startup. Since they are no longer on your computer. Your system goes through a long search trying to find them. You need to clean and optimize your Windows registry to eliminate any bad or orphaned files.
You can do this manually if you are an experienced computer technician. It is not recommended for most users. Windows does not have a built-in tool for repairing, cleaning, or optimizing your registry. You will need to download and run a third-party registry repair program to do this.
A good piece of software that will do this for you with a click of the mouse is a wise investment for any computer. You will have it for years to come, and can schedule it to do weekly maintenance. This will keep your PC fully optimize and running fast. It's like giving your computer a tuneup.
Jun 17, 2011 | Microsoft Windows Vista Ultimate Edition
Computer very slow ,won't print,forever to load pages, have corrupted files
Several things can slow down the computer: overheating, spyware, not enough RAM etc. If you know for sure you have corrupted files were they corrupted by a virus? You may need to reinstall Vista.
Is it slow when you boot up in safe mode? To boot into safe mode hit (usually) F8 while it is booting up. Let it completely boot into safe mode and then reboot again. Now is if it is behaving better.
To get rid of spyware download the free Spybot Search & Destroy from the net, run the update and then run it to dectect and get rid of the spyware. Spyware tries to send info which can slow down everything.
Overheating - does it feel hot? Is the fan running and pushing air?
If it worked fine before it is unlikely you don't have enough RAM. Windows itself needs at least 256mbs to run well without running other problems.
Again if you know files are corrupted, if they are windows files, you might need to reinstall vista.
Feb 22, 2011 | Microsoft Windows Vista Home Basic Edition
Dell Studio had boot problems. Analysis showed registry was damaged. Decided to repair Windows Vista. Put in Windows Vista DVD and began installation. At normal mid installation re-boot, laptop restarts...
Its better if you can reinstall the OS...
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If you dont find this default partition then go ahead and reinstall the OS and then install all the drivers for the system....
Sep 19, 2010 | Dell Studio 1737 Laptop
Slow running PC
What about checking for viruse, malware and spyware. Use Malware Bytes and Superantispyware. I'll bet you'll find your culprit.
Mar 24, 2009 | Computers & Internet
Uninstallation of Windows Vista ultimate Edition
Just boot from the installation cd. when prompted to repair or don't repair choose don't repair on the next step you'll asked to format the hardisk or leave the current partition. if you dont have any important data I recommend to format your hardisk. Backup yaour data before installing
Mar 21, 2009 | Microsoft Windows Vista Ultimate Edition
Unable boot vista ultimate (installed earlier) after installing new xps2
You have to reinstall vista bootloader.
Just insert vista dvd in the drive and boot from it.
Select startup repair and it will fix everything back to normal.
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot reboot Vista after downloading a security update for LimeWire?
its seems that you have to repair the os,repair it or reinstall it
May 07, 2008 | Microsoft Windows Vista Ultimate Edition
WIndows Vista, trying to reinstall but CD with OS not working...
It sounds like the CD is faulty. Can you take it to a local PC shop & ask them to check it for you? Also, try cleaning the CD - I have come across drives which wouldn't read a disc if it had a very visible fingerprint on it.
Dec 19, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
107 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
