Question about Polaris 380 In Ground Pool Cleaner
Polaris 380 circles to the right
My Polaris 380 is circling in a pretty tight loop, going to the right all the time. I just replaced the tires and drive belts, so the wheels seem to be working well. The float seems OK (no water in it when I shake it). I adjusted the jet on the back to compensate to push it left, but it doesn't seem to matter.
    Top Expert:
  • Polaris Master
  • 6,949 Answers
Make sure thruster is at 11:00
Posted on Apr 23, 2016
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
  • 128 Answers
SOURCE: Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Posted on Aug 23, 2009
  • 990 Answers
SOURCE: My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Posted on Aug 25, 2009
  • 128 Answers
SOURCE: Polaris 380 wont run when vertical
The drive belts are loose. Replace the drive belts are at least take the cover off inspect and tighten. The adjustments are the axle blocks. Tighten to where there is about an 1/8" tension while lightly pushing on the belt.
Posted on Aug 30, 2009
  • 10 Answers
SOURCE: Polaris moves in circles
Check the football looking ballast float on the back of the cleaner. You want make sure it has no water inside of it. You can pull it off and shake it next to your ear. Link to Head Float.
Posted on Nov 03, 2009
How do I design a 6 foot diameter circle for my garden?
drive a peg in the ground where you want the center of the circle to be
get a piece of string and make a loop at one enf big enough to fall over the peg
measure out 3 ft from that loop and tie a stake at that point
now pull the string until it is tight and where the peg hits the ground make a mark
move about a foot an make another mark keeping the string tight all the whole
repeat the process until you have done a complete circle
the marks will be the circumference of a 6 foot diameter circle
Oct 12, 2014 | Esschert Design USA Esschert Design...
Polaris 340 goes in circles
make sure output of unit is aimed at 11:00
Apr 10, 2014 | Polaris 380 In Ground Pool Cleaner
Hayward great white just spins in circles
Could you clarify the exact model? The picture shows a Polaris 380, and the Great White is built by Sta-Rite/ Pentair,(now sold under the name Kreepy Krauly), not Hayward.
Confused yet? Don't feel bad, I am too!
Sep 15, 2013 | Polaris 380 In Ground Pool Cleaner
It goes in circles. It just makes tight turns on the bottom of the pool.
A cleaner going in circles is an indication of a problem with the drive mechanism on the same side as the unit turns. If cleaner uses drive belts, check them for tension or wear. If direct drive, it may be either the drive linkage or a damaged/worn impeller. Unless your are confident with repairing the unit yourself, this is a job for an experienced pool equipment technician. You can still troubleshoot the problem by running the unit on its side in shallow water and observing the relative drive speeds on each side.
Nov 07, 2010 | Polaris 3900 Sport Pool Cleaner ()
Machine keeps going around in circles jet at back is going straight back?
Few different things can cause this. Wheel bearings can be bad, tires worn, teeth on gears inside wheels stripped or broken, or the teeth on drive shaft worn or broken. Low pressure or clogged line can also cause to run sparatic, but not necessarily in circles. Most likely problem is with bearings, or wheels. Check these closely for problems. Most pool stores with check it and replace parts (that you purchase) for free.
Sep 21, 2010 | Polaris 380 In Ground Pool Cleaner
My P380 moves around the pool but does not pick up debri...
Make sure the wall screen is clean. It sounds like you are missing the wall fitting screen. If this is the case you have debrie in the unit and it has plugged the water management system. Take the cover off the head and clear all the jets where the hoses connect.
Aug 26, 2009 | Polaris 380 Automatic Pool Cleaner with...
Jul 05, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
749 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
