Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Flashing red light
My CE-200 WILL NOT SEW THE ERRO LIGHT CAME ON EACH TIME I TRY TO SEW I DONT KNOW WHAT TO TOUCH BUT ITS FAIRLEY NEW SINCE I BAUGHT I ONLY SEW 4 COUSHION AND TEST THE EMBROD.
  • 23 Answers
Are you sure you have turned the foot button underneath the machine back to normal stiching and also then again for embroidary and have you placed the protective cover back for normal stiching once you removed the embroidary arm.
Posted on Mar 31, 2009
Singer CE-200
since it is a embroidery machine I would suggest the technican
to be on the safe side
Jun 03, 2012 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
My grandma bought a singer Futura CE-200 and only used it once because she got frustrated with it. She gave it to me and she has lost the cd. I can't sew at all because it flashes red lights and stops...
in case you can't get one from a user here,, you can get one I believe from here http://blog.jennys-sewing-studio.com/?cat=34 which includes all the updates that your machine requires,, I don't know of the cost ,, but didn't want to leave you completely stranded,,
Oct 07, 2011 | Singer CE-200 Quantum Futura Computerized...
Machine will only work in reverse
If it is like one of the machines I have, you can set it to do mending and embroidery so that the feed dogs to not advance the material. If so, there should be a dial that allows you to re-set it so the feed dogs are not depressed. Hope this helps.
Mar 18, 2009 | Singer CE-200 Quantum Futura Computerized...
When Sewing a straight stitch machine stops
rethread the top thread, it thinks the thread broke.
I have a Singer Futura CE-100. I have had it for 3 years but have not used it much because I can't get the tension correct. I have had it repaired/maintained twice most recently this week. I can now sew on...
Sad to say you might have to do an indept check. Like start with a small peice of fabric - start with the highest bobbin tension and go to the lowest - leaving the top tension the same. Write all the findings. Then do it all again with the next top tension. Keep your 'good' findings in a little notepad in your sewing box. Then you will have it all ready for any other project. Good luck!
Jan 25, 2009 | Singer CE-200 Quantum Futura Computerized...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing patiala salwar
Hi Tamanna,
Sorry i dont know how to sew but i can give you a link sewing.about.com is were you can find help on how to sewing patiala salwar it`s got lots of tips on sewing i hope this is helpful to you.
Oct 29, 2007 | Singer CE-200 Quantum Futura Computerized...
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
226 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
