Low sound on desktop pc
Here is my dilemma: SOUND and VOLUME on SPEAKERS
I have a MPC ClientPro 414 all-in-one with a Lenovo ThinkPad UltraNav SK-8845 keyboard running on Windows XP.
I cannot seem to get the internal speakers working even though I can change the slider position using the function keys.
I cannot get sound from external speakers (plugged into the lime green female thingie).
I CAN get a low volume sound from external speakers with BOOSTER that plugs into the wall when plugged into the lime green plug thingie. It is still VERY low and almost inaudible.
I am thinking of giving up my search for a solution without putting money into it by buying a StarTech USB 2.0 Audio Adapter 7.1 and plugging that into my usb slot and then plugging my external speakers in there. Will that work to get an audible sound on this thing???
Thanks in advance.
  • Tricia Mar 08, 2009
    It is horizontal (PCMCIA Card?)
    PLAN A?- If it is replacing the PCMCIA card (there is not one currently in there just a dummy plastic black piece) I would actually be putting one in. The cheapest I could find was $50+
    PLAN B- the USB 2.0 Audio Adapter is under $20 including shipping. This will take up a USB port but there are plenty of those on this machine.
    PLAN B will accomplish increasing the volume no?
    What is weird is that there is a volume dial on the schematics that I found online on the computer monitor but on my actual computer there is a dummy black knob as if there was never a dial installed??
    Thanks for your QUICK response...I have been at this, hate to admit wasted time but almost 12 hours!!! And that is just today!
    And yes, I have checked everything from sound properties and device manager, etc.
    I had read on another forum that with this sound card that I have Vinyl AC'97 Codec Combo Driver (WDM) that there was some update to the driver that Microsoft put out that messed up the driver but I cannot confirm that. So, that could also be the problem. I have already re-installed the driver though and no diff. in sound volume, etc.
    Thanks again!
    Tricia
    NOVICE :-)
    Scholar:
  • 44 Answers
I have extensive experience with the CP414 (I used to work for the company that supplied it to MPC). It sounds to me like you have a broken volume knob. On the bottom edge of the LCD panel, just to the right of the MPC logo, there should be a volume control knob. This knob should only be able to turn through about 270 degrees of rotation. If it rotates freely, it is broken. These tend to break if they are hit from below. (This can happen during assembly at the MPC factory -- if a technician props the LCD panel up on its bottom edge, it will damage the volume knob.)
There are a few solutions:
#1: This is probably the easiest one to accomplish. Remove the cable door on the back of the system (it is the one at the bottom on the back -- held in by one screw). Under this door there are anywhere from 5-6 cables plugged into the motherboard. One of these is a connector with 30 pins arranged in two rows of 15. The cable plugged into this connector probably has pink wires. Short pins 7-8 on this connector (they should be across from each other, but only pins 1, 2, 29, and 30 are labeled). To short the pins, insert a thin wire into the back side of the connector so that it makes contact with the exposed pins. You could also use a resistor to do the trick - 10KOhms will give you no volume while 0Ohms will give you full volume. Something like 2.5K could give you a nice middle ground.
#2: Replace the volume knob. The part number for the knob is XV0107GPV2NB10K-3824. Good luck finding someone who will sell you one of these.
#3: Disassemble the LCD panel (it's not that hard if you have a #1 phillips screw driver) and short the volume control knob pins 2-3. This will disable the volume control completely, but it will be stuck on maximum volume. This would be best done by soldering a wire between those two pins.
Options 1 and 3 will disable the hardware volume control, but the software volume control in Windows will still work fine.
Posted on Jul 01, 2009
    Scholar:
  • 82 Answers
It should....depending on the problem you have now. Are you sure you have checked the sound properties and device manager to be sure they are not turned off or there are no conflicting settings selected? If so, then you probably have a defective sound card. Are the inputs for your sound on the back of the computer in a horizontal or vertical row??? If vertical, that means on-board audio. If horizontal, then it is a pci sound card. The pci card is pretty easily replaced, for about $20 if you do it yourself. If it is onboard, then you will have to research your motherboard before installing the card because sometimes you have to adjust a jumper setting on the motherboard in order to disable the on-board audio. In any case, the usb adaptor should bypass the on-board with software. Good luck!
Posted on Mar 08, 2009
    Problem Solver:
  • 9 Answers
It should.
Pins in power adaptor will not insert into place where adapter is to plug in
HI
The port of the power adapter for your MPC Computers ClientPro 414 All-In-One PC MUST be the same below
Dec 07, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Where do i get the ethernet driver for my mpc clientpro 414
ClientPro 414 Ethernet Driver >>Click here to download Windows XP Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN DriverClick here to download Windows XP x64 Edition Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN Driver
Oct 21, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Have an mpc 'clientpro 414 all in one' and I don't know how to get into bios... Having a problem of no sounds; troubleshooting leads me to check if sounds turned off in bios..
to get in to bios you have to press DEL or F! when the system start then you can enter bios the problem of sound can be the corrupted sound drivers uninstall the sound drivers and install them
Nov 28, 2010 | MPC Computers ClientPro 414 All-In-One PC...
I need IDE adapter for MPC 414. Hard drive to MB,fits in caddy. Appears to be an edge connector?
You can contact Patrick Albright at Tangent, 1-800-342-9388 x1772 they are carrying the MPC parts these days. I just talked to him.
Aug 21, 2009 | MPC Computers ClientPro 414 All-In-One PC...
ClientPro 414 Parts Source
I have many spare parts and memory for ClientPro 414. Please contact me for more info.
Apr 08, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Low volume on external speakers, no volume on internal
I have all the audio drivers for that model. Please let me know what operating system you are using. These are large files, around 7mb for xp.
Mar 07, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Siemens fujitsu scalo p.....can't get my 2.1 speakers to work
Hi There Try this, CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them with a new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | MPC Computers ClientPro 414 All-In-One PC...
Computers & Internet Logo
366 people viewed this question
David Payne
David Payne
