Question about Uniden TRU8885-2 Cordless Phone
Handset No2 displays out of range message
When I try to use the handset by pushing the talk button a message out of range appears.
Number one hand set works OK.
  • Anonymous Mar 15, 2014
    message number to get my messages from handset
    Problem Solver:
  • 8 Answers
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Posted on May 06, 2009
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
I have a three hand set GE dect 6.0 one of the handsets will not activate, it keeps showing me "Out of Range" I have tried many times to set it up but it always give me the same message "out of range". Can...
On the handset, look for the "PROGRAM" button and choose "HANDSET SETUP". Scroll through the menu to find "REGISTRATION" and select it. The handset display should then prompt you to press and hold the "PAGE" button on the base unit for 5 seconds and then press the "PROGRAM" button on the handset.
Perhaps you've already tried this process, as you indicated your attempts "to set it up". This is what worked for my GE DECT phones when one of the handsets displayed "Out of Range" after an electrical storm. Best of luck to you!
Jul 09, 2009 | Thomson GE 27907GE1 Cordless Phone
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
Handset
Presume you are talking about the extra handset. Try placing the extra handset in the "main" base for 5 seconds.
Aug 27, 2007 | Sony SPP N1025 Cordless Phone (spp-n1025)
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Couldn't make any calls
You might try unplugging the base AND removing the batteries from the handset for 30 minutes. Then reinsert the batteries, place the handset in the cradle in the base, and then plug the base back in. This might allow the handset and the base to re-sync with each other.
Mar 15, 2007 | Panasonic KX-TG2740S Digital Answering...
Uniden TRU8885-2 Cordless Phone Logo
964 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
