I have a toshiba IP phone... IPT2010-SD...Had a problem with the internet but that is resolved and now the phone says IPaddress setting.... on the phone do you resolve this and make it work?
  • Anonymous May 03, 2009
2 Suggested Answers
SOURCE: I have a toshiba IP
Hi ghefner,
I see you need assistance with you IP phone you say the internet is now working and now the phone says IPaddress setting, seems that your IP phone need to be set properly again with the IP address settings and info regarding your Internet or IP phone.
Who is you internet provider? We really will not be able to tell you information regarding your IP address since your internet service provider who gave you the phone can give you that info.
regardless of your IP addresses that you need to enter on your phone I can only provide a manual on the issue on how to configure the functions back again but the IP addresses thatyou need will come from your Internet Service Provider
See this link for the Manual on how to set things up.
Hope this helps on setting things up.
Posted on Jul 13, 2011
Can't access to internet service
Turn off your internet modem or router for about 5 minutes. After 5 minutes turn on you internet modem or router and turn on your computer and when you are already on your desktop click start and click run then type cmd and press enter. On the command prompt type ipconfig/all and press enter and the ipaddress and gateway will appear on your screen but in case there is or no ipaddress and gateway type ipconfig/release then type ipconfig/renew this process will erase the IP settings and renew the IP and gateway. Also check your modem or router if the lights of the modem are blinking, usually three or four lights that are blinking. If the two lights blinking only call your Internet service provider and ask for assistance that you are having difficulties with internet connection. Have a nice day.
Mar 18, 2011 | Computers & Internet
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g
13.) as your primary dns enter your modem ip e,g
14 save changes and exit
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g
Enter the Prefered Dns as also your Modem ip
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
I cannot connect to the internet with the wireless connect, it is showing that the wireless is connected and the signal is excellent, but when I try to get on the internet I get a message saying the page...
I got your issue , If you need to check the ipaddress on the wired computer which is online. You need to check the ipaddress on the wired
So please follow these steps.
1. Click on start--> go to RUN --> in Run you type in "cmd" and click ok
(If you do not find RUN in the start search box type RUN and hit enter)
2.You will get a black screen(command prompt) , there type in "ipconfig" and hit enter
3.Please make a note of the ipaddress (or it says ip V4 ipaddress) , it will be like / /
Now move to your wireless computer
1. Click on start --> go to control panel
2. Go to network and sharing center (or network and internet connection in xp , then network connection)
3. In the left side click on manage network connection in vista
change adapter settings in win 7
4. If you find the wireless network connection, right click on it and go to properties
5. select Internet protocl TCP/IP(ver:4 in vista & Win 7) and click on properties
6. change it to use the following IP address
7. Then type ipaddress : (provided IPaddress in the wired comp is 192.168.2.x, if its diff change it accordingly)
subnetmask :
Default gateway :
8. Change to Use the following DNS server address
Preferred DNS : & alternate :
Im sure this will work
Thanks & Regards,
Oct 11, 2010 | Computers & Internet
Using linksys wet11 to connect to internet through linksys wireless router, working before, suddenly, not working, trying to setup again using static IP, not working, using DHCP, not working, run...
it's because you need to change the ipaddress in you linksys
make sure the ipaddress from you modem it's not
if you have the same ipaddress on the modem try changin the ipaddress on the linksys to
Oct 15, 2009 | Linksys 802.11b Wireless Ethernet Bridge:...
I have the HERMO packard bell model. I can hardly access internet and the sound is not heard. Please hhelp
For internet
First check ipaddress
Click Start -run- type cmd hit enter for XP or Start -search-type cmd hit enter in Vista. On the DOS black screen after the blinking cursor type ipconfig hit enter check the ipaddress if are getting ipaddress other than (169........) it is proper ipaddress for e.g
Ping the default gateway e.g ping 147.11.445.478 if you are able to get packets send 4 received 4 loss zero is with Internet explorer or operating system.
If unable to ping or getting 169..... ipaddress . you are having static ip address
On the black screen at the blinking cursor type ipconfig /release hit enter
then type ipconfig /renew hit enter .check ip address
Ping default gateway then ping if you are able to get packets send 4 received 4 loss 0. Try connect to internet using internet explorer or other browser. if still unable to connect then issue with firewall or antivirus or IE corruption .
Create new administrative account in XP and do MSconfig .Restart the system and logon to new account and try connecting to internet.
If issue persist might have to repair IE or operating system as it is software issue or virus issue.
You can connect a different computer if you have one and check internet.
If unable to get any ipaddress or still getting static ip address ,reset modem or check ethernet cable ,do a hard reset on the internet modem.Shutdown and restart computer and check ipaddress then try connecting to internet.
NO sound : Check the sound driver .Try reinstalling sound drivers
Aug 24, 2009 | Computers & Internet
Port setting to allow my xbox to run games
Hello djand2kidz,
Inorder to resolve this we need to open application ports for the Xboxconnection. This problem can be resolve by any of the following:
  1. Opening port Numbers TCP 88, TCP/UDP 3074
  2. Lowering MTU size and Disabling SPI
  3. Enabling UPnP
  4. Enabling DMZ
  5. Upgrading the firmware of the router.
  6. Set NAT filtering to open (Only available on WGR614v6, v7, and v8)
Here are theoptions on how your Xbox connected to the internet. Opening Port Numbers TCP 88, TCP/UDP 3074:
1. Make sure that Xbox has valid IPaddress of the same range of the Netgear router.
Assign static IP address on Xbox.The following values should be used while assigning static IP address on theXbox.
IP Address: 192.168.1.x (e.g.
Subnet Mask:
Default Gateway:
Note: Here ‘x’ can be any uniquenumber from 2 to 254 depending upon the IP address assigned to remainingcomputers in your network.
3. Oncestatic IP address is assigned, the requisite port numbers can be open using thesteps below.
a. Open the browser(Internet Explorer or Netscape) and type the IP address of the Router( in the address bar.
b. It will prompt youto Login into the Router (Username = “admin” & Password = “password”).
c. Select "Port Forwarding" under "Advance"
d. Select "Port Forwading" under "Service Type"
e. Click on "Add Custom Service"
f. Prepare the following Service for opening port 88 TCP/UDP.
g. Clcik on "APPLY" after creating Xbox_1
h. Again click on ‘Add Custom service and thenenter the values to open port number TCP/UDP 3074.
i. Click on ‘Apply’ after creating Service Xbox_2.
j. OnceXbox_1 and Xbox_2 services are created you will there entries under ‘PortForwarding/Port Triggering Option.
Mar 29, 2009 | NetGear WGR614 Wireless Router
Ipu not found on a toshiba ip series ip5022-sd
Bring the IP phone to the office and connect to a data jack.
if you connect the ip phone is good and you might have a rest. router.
Dec 24, 2008 | Toshiba DKT-2020 Corded Phone
Wireless connection on qosmio G25-513 not working
access your router with following link
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically
then enable in your intel pro ipaddress properties auto get ip addrese.
thats it.
Nov 13, 2008 | Toshiba Qosmio G25-AV513 Notebook
My brother printer MFC-640CW has stopped taking comand to print documents from my computer, i can copy and scan, but not print . ink pads are full.
Make sure the status and configuration of the print server. Check following:
1 Make sure that the machine is powered on, is on-line and ready to print.
2 Print the Network Configuration List of the machine and check if the settings such as IP address settings
are correct for your network. The problem may be the result of mismatched or duplicate IP address.
Verify that the IP address is correctly loaded into the print server. And make sure that no other nodes on
the network have this IP address.
3 Verify that the print server is on your network as follows:
For Windows®
(1) Try pinging the print server from the host operating system command prompt with the command:
ping ipaddress
Where ipaddress is the print server IP address (note that in some instances it can take up to two
minutes for the print server to load its IP address after setting the IP address).
(2) If a successful response is received, then proceed to Windows® 98/98SE/Me Peer-to-Peer print
(LPR) troubleshooting
. Otherwise, proceed to Step 4.
4 Reset the print server back to the default factory settings and try from the initial setup again. For
information how to reset to the default factory settings, see Restoring the network settings to factory in the manual.
Jul 01, 2008 | Brother Office Equipment & Supplies
Ps3 keeps on saying ip timed out
your ip settings are most likely wrong, check your desktop pc settings
here is how
start -> run -> cmd -> ipconfig
note, ipaddress, subnet, gateway
if your desktops ip is similiar to 192.168.1. 2 to 254
then set your ps3's ip as for example
just a number between 2 and 254 (the 1 is used by router) witch isnt used.
your address might show for example or a more complex ip like if this is the case set the ps3 on automatically get ipaddress and dns server.
if you need any help let me know. Good luck.
Apr 02, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
768 people viewed this question
David Payne
David Payne
