Question about ASUS A7V333-X (A7V333-X/L) Motherboard
Jumper connections a7v333 asus
Ok ,I air cleaned my computer and jumpers came out, try to put'em back but stayed with one.Wonder if anyone could find me a diagram to put them back at there right place.
My e-mail adress is
Thanks in advance!
  • Michael Thomas
    Michael Thomas May 11, 2010
    Hi there
    you can go to the manufacture of the motherboard web site and they will have the diagaram of the motherboard or you can go to the manufacture of the computer and get technical help fro mthem too
  • 83 Answers
Go to below link and download manual of ur motherboard...
and refer the diagram..
If problem not solve so pls reply me..
thanks and RATE ME
Posted on Mar 08, 2009
Ram beep ok but no display
try reseting the bios using the jumper method. you should find a jumper near your cmos battery. turn your computer off, unplug the power cord. The jumper should be in position 12.. set it on ..23. Press power button with power cord still unplugged. Let it stay like this 1 or 2 minutes. Set the jumper back in position 12..., plug the power cord then turn your PC on. If this doesn't work, simply take out the cmos battery and stay with it like 3 minutes. Put it back in place, then turn your pc on.
Jan 15, 2011 | Intel D845GVSR Motherboard
After replacing on board lithium cell, computer will not boot up. Goes through BIOS ok but no further, even tried replacing hard disk and booting from removable media drives (after setting BIOS...
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
Jan 11, 2011 | ASUS A7V333 Motherboard
Bios can't run after clear CLRTC
If you used a jumper to clear the CMOS, be sure that you put the jumper back like it was or the computer will not boot up. Normally that jumper will be on pins 1 & 2. To clear the CMOS, you pull the battery out and put the jumper on pins 2 & 3 for a couple minutes. Put the battery back in and put the jumper back on 1 & 2.
Apr 05, 2009 | ASUS P5GD1 Motherboard
Dvd writter problem in asus motherboard
We likely have a "Jumper" issue here. On the back of the Drive right next to the Data cable there should be a group of jumper pins along with a general diagram or the jumper settings.
The diagram will likely be stamped in the metal next to the jumper group, or on the label.
The settings we are concerned with are CS (Cable Select), M (Master) and S (Slave)
First one I want you to try is CS move the jumper block to connect the pins for CS (If there is another drive on that cable, its jumper should be set to CS as well)
Now try to boot up again. If it works, you are good to go.
If not try the M setting on this drive. If it shares the cable the OTHER drive should be set to S this time.
Now try again. If still no luck reverse which is M and which is S
and try once more.
If ALL of these options fail, please post back here and we will try to assist you further.
Nov 15, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Motherboard jumpers
ur see back is the jumper
Oct 24, 2008 | ASUS P4SGX-MX Motherboard
Keyboard stays on
I would first Reset the CMOS... do this by switching the jumper pin cap from 2-3 to 1-2 then give it power/and immediately power off.. then reset jumper cap position to original spot... the jumper can be located usually near the CMOS battery.
Jun 01, 2008 | ASUS A8N-SLI Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
May 15, 2008 | ASUS P5PE-VM Motherboard
Asus a7v333 motherboard
try and update your bios, hopefully your timings, were just messed up by the new memory, or you could try a cmos jumper reset.
Mar 03, 2008 | ASUS A7V333-X (A7V333-X/L) Motherboard
I changed RAM settings in BIOS, now I can't boot
try jumpers ok move to 2 and 3 for few sec then back on 1 and 2 pins on mobo ok thx nick take ram out do one at time defult to auto in bios thx nick
Feb 06, 2008 | ASUS P4S533-MX Motherboard
No video etc.
on the motherboard will be a JBAT1 terminal with the jumper across pins 1-2, so put jumper on pins 2-3, then back to pins 1-2. If not JBAT1, then it may be a 2 pin terminal called CLRCMOS, of which you put a jumper across the two pins for seconds then remove. Although, i can't think of a way to update the bios without seeing whats on the screen.
Mar 27, 2007 | ASUS Intel 440BX Chipset P2B Motherboard
ASUS A7V333-X (A7V333-X/L) Motherboard Logo
522 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
