Question about Acer Aspire 3000 Notebook
Main motherboard overheating ...screen won't turn on when i turn the on button
  • esemrloki697 May 11, 2010
    Problem Solver:
  • 9 Answers
Solution!!!!!!!!!!!, Be sure to check your heat sinks, or add and replace new one's if they look worn out. another thing!, it is possibly your coolant fan. are you sure its the motherboard in your exsplenation? and how do you know its your motherboard. is it hot? could also have a lightbulb blown out in your (LCD) causeing you not to see your screen. if you have anymore question's ask me anytime.
Posted on Mar 08, 2009
My pavilion dv5-2231 nr Entertainment PC won't turn back on. When I press the power button it flashes along with the f12 button and nothing else happens. The screen doesn't even turn on. Help!
It looks like it may have overheated and the motherboard may be damaged. Remove the RAM and hdd. Try and boot to DOS. If it does, the motherboard is probably OK, if not seek a GPU reball.
Oct 16, 2015 | Pavilion Computers & Internet
Freezes during start up inspiron 9400
>Hard drive failed
>Memory went bad
>Motherboard failed
Google/search tests for above.
Aug 29, 2013 | Dell Inspiron Computers & Internet
The back light won't turn on and the volume is turned all the way up but the buttons won't work for me to turn it down. I had to take the whole thing out
Assuming your deck is a kdc 516s the flexible cable that goes from the face to the main motherboard is probably bad. If you are not good at desoldering and soldering. , I would suggest you have it replaced by a professional.
May 06, 2012 | Kenwood KDC-516S CD Player
I have a hp netbook laptop and it was working earlier but when I opened it it flashed my login screen and shut off and I can't get it back on and when I press the turn on button the charging button...
Remove the main battery and press power, sometimes this will solve the problem. If not, remove one stick of ram and power on, if not remove the second one and replace the first and try again. If no result it is probably a motherboard issue.
Mar 10, 2012 | HP Computers & Internet
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
The laptop was turning on when i press on the power button but after a few second turning off by itself
It may be overheating or something is damaged on the main motherboard. If you have a warranty, you should use it.
Another possibility is that the power button may be stuck and the laptop may not recognize that the button has been released. This can sometimes cause that problem. Cleaning around it, or taking apart the laptop for a good thorough clean, can usually fix it. If you take apart the laptop, the warranty may be void.
May 22, 2011 | Compaq Computers & Internet
My compaq presario cq60 was working fine last night and it turned off like regular when i turned it off. today i turned it on and at first it turned on but then it shut off and now it wont turn on or make...
Try removing the battery and unplugging from the mains. Press and hold the power button for 30 seconds then reinsert the ac adaptor and try to power on.
If that doesn't work I think you may have a problem with the motherboard. Overheating commonly causes these issues, also if you plugged in the external monitor with the laptop "live" this might have caused some damege
Dec 28, 2010 | Computers & Internet
My pc frequently restarting anytime
It may be possible that your CPU is overheating and the BIOS restarts your computer for safety reasons.
You should open the tower and clean the inside of it. Unplug the cooler from the processor, clean the fan od the cooler, install new cooling paste on the processor and put them back.
It should work perfectly.
N.B: Do not change the BIOS settings.
If you need further assistance, leave a comment.
Jun 08, 2010 | Intel D865GBF Motherboard
My hp dv6125se
If you have power as you say w/ the lights but no screen, the first thing I would check is by reseating the memory modules in the computer. If that does not work possibly trying a new one.
Second it could be the processor overheated and may have worked loose, it would need checked and reseated.
If that does not work, I would have to say that it is entirely possible that the video section could have a problem, or another power fault with the mainboard.
After all that, I will say, YES it is possible the main board could be the culprit. At one time I know some DV6000's (certain pn#'s) had a recall for main board issues.
May 03, 2010 | HP Pavilion dv6000z Notebook
Acer Aspire 3000 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
