By paulrmc - usenet poster
I would like to read some SUN binary data files - ieee fp
big endian - on digital mchines. The DEC fortran compiler
has an option (convert) to read non-native binaries, and this
works fine with an alpha running OSF, but I can't get it
to work with VMS.
The problem could be with my open statement or with the file
getting screwed up by FTP. Can anyone throw any light on this
for me?
Simon Williams
Solution #1
posted on Aug 02, 2007
Reynolds - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Yes, the option works on OpenVMS, but it affects data only. Digital Fortran
on OpenVMS doesn't understand the UNIX Fortran "unformatted" recordtype which
has 32-bit record lengths at the beginning and end of each record. (We may
add such support in the future.)
Steve Lionel mailto:
Fortran Development #
Digital Equipment Corporation
110 Spit Brook Road, ZKO2-3/N30
Nashua, NH 03062-2698 "Free advice is worth every cent"
For information on Digital Fortran, see #
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Peter1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
As Simon is based at Rutherford Appleton Laboratory, I have replied
direct to him. I am confident that the DEC extension keyword
CONVERT="LITTLE_ENDIAN" works in both OSF and VMS, so his problem may
be the FTP transfer.
Jonathan Wheeler
Systems and User Support Group
Department for Computation and Information
Jonathan Wheeler
Solution #3
Chandler - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The problem is that the VMS system doesn't understand the typical UNIX
Fortran unformatted file format where records are preceded and followed by
a byte count. This is needed on UNIX systems since they have no concept of
record attributes.
But not to worry - I've got a program that will convert the record format
for you. Use this, and then you can read the file with FORM='UNFORMATTED',
CONVERT='BIG_ENDIAN'. The program I'll supply here converts to the
OpenVMS Fortran 'SEGMENTED' recordtype (not a true VMS recordtype, but the
one you get by default with Fortran unformatted files.) If you want one
that converts to 'VARIABLE', I have that too - just send me mail.
My apologies for the crude user interface for the program - I did this as
a demo of the conversion technique and didn't spiff it up. Also, I haven't
tested this on a file with big-endian record lengths, though the program I
adapted it from (which accepts little-endian record lengths) works fine.
Let me know if it doesn't (or does!) work or if you have any questions
about it.
PROGRAM BIGEND_TO_SEGMENTED
C+
C
C ABSTRACT:
C
C Converts big-endian UNIXunformatted files to OpenVMS Fortran 'SEGMENTED'
C
C FUNCTIONAL DESCRIPTION:
C
C Input file is specified by the logical name FOR001, FOR001.DAT is used
C if not defined. This must be a file written a big-endian UNIX system
C as an UNFORMATTED file with the default recordtype that has the data
C preceded and followed by a 32-bit record length (in bytes). The file
C should be copied to the OpenVMS system using FTP BINARY GET or DECnet
C COPY. The OpenVMS record format of this file may be FIX or STM_LF -
C it should not be VAR.
C
C This program does not do any conversion of the actual data - it just
C converts the record format. Use CONVERT='BIG_ENDIAN' in an OPEN
C statement to do data conversion.
C
C Output file is specified by the logical name FOR002, FOR002.DAT is used
C if not defined. The input file is converted to an OpenVMS Fortran
C 'SEGMENTED' unformatted file.
C
C AUTHOR(S):
C
C Steven B. Lionel
C
C CREATION DATE:
C
C 30-Sep-1996 (from little-endian version of 2-May-1996)
C
C DESIGN:
C
C The program assumes the input file is of the correct record format.
C A command line interface might be a nice extension.
C It's possible that a very large input file might require process
C quotas to be raised. An implementation using block I/O is feasible
C but much more complicated
C
C
C MODIFICATION HISTORY:
C
C Date | Name | Description
C ++---
C 30-SEP-1996 | SBL | V1-1 Original
C ++---
C [change_entry]
C-
IMPLICIT NONE
INCLUDE '($SYSSRVNAM)'
INCLUDE '($SECDEF)'
INTEGER CHANNEL, BYTES_IN_BUFFER
COMMON CHANNEL, BYTES_IN_BUFFER
EXTERNAL UFO_OPEN
INTEGER STATUS
INTEGER*2 FLAGS
INTEGER*4 UNIX_RECLEN,UNIX_RECLEN_END
PARAMETER FIRST_SEGMENT = 1
PARAMETER LAST_SEGMENT = 2
PARAMETER MAX_SEGMENT_SIZE = 1024
BYTE UNIX_REC(MAX_SEGMENT_SIZE), LAST_BYTE
POINTER (UNIX_REC_P, UNIX_REC)
POINTER (UNIX_RECLEN_P, UNIX_RECLEN)
POINTER (UNIX_RECLEN_P, LAST_BYTE)
POINTER (UNIX_RECLEN_END_P, UNIX_RECLEN_END)
INTEGER RECLEN_TO_GO
INTEGER*4 I, UFO_OPEN
INTEGER*4 RETADR(2)
INTEGER*4 INADR(2) /0,0/
! Open input file and get channel/size (in COMMON)
OPEN (UNIT=1,STATUS='OLD',READONLY,
1 USEROPEN=UFO_OPEN,FORM='UNFORMATTED')
CLOSE (UNIT=1)
! Map input file as private section
STATUS = SYS$CRMPSC (
1 INADR,
1 RETADR,
1 %VAL(0), ! acmode
1 %VAL(SEC$M_EXPREG),
1 %VAL(0), ! gsdnam
1 %VAL(0), ! ident
1 %VAL(0), ! relpag
1 %VAL(CHANNEL), ! chan
1 %VAL(0), ! pagcnt
1 %VAL(0), ! vbn
1 %VAL(0), ! prot
1 %VAL(4)) ! pfc
IF (.NOT. STATUS) CALL LIB$STOP(%VAL(STATUS))
! Open output file - this is going to be a 'SEGMENTED' file but we'll
! handle the segmentation ourselves
OPEN (UNIT=2,STATUS='NEW',RECORDTYPE='VARIABLE',
1 FORM='UNFORMATTED',RECL=2048)
! Set up the buffer pointers
UNIX_RECLEN_P = RETADR(1)
UNIX_REC_P = UNIX_RECLEN_P + 4
! Copy the file
DO WHILE (BYTES_IN_BUFFER .GE. 8)
! Consistency checking
CALL SWAP_RECLEN(UNIX_RECLEN)
IF ((UNIX_RECLEN + 8) .GT. BYTES_IN_BUFFER) GOTO 810
UNIX_RECLEN_END_P = UNIX_RECLEN_P + UNIX_RECLEN + 4
CALL SWAP_RECLEN(UNIX_RECLEN_END)
IF (UNIX_RECLEN_END .NE. UNIX_RECLEN) GOTO 820
FLAGS = FIRST_SEGMENT
RECLEN_TO_GO = UNIX_RECLEN
! Write intermediate segments, if any
DO WHILE (RECLEN_TO_GO .GT. MAX_SEGMENT_SIZE)
WRITE (2) FLAGS,UNIX_REC
FLAGS = 0
RECLEN_TO_GO = RECLEN_TO_GO - MAX_SEGMENT_SIZE
UNIX_REC_P = UNIX_REC_P + MAX_SEGMENT_SIZE
END DO
! Write last record
FLAGS = FLAGS .OR. LAST_SEGMENT
WRITE (2) FLAGS,(UNIX_REC(I),I=1,RECLEN_TO_GO)
BYTES_IN_BUFFER = BYTES_IN_BUFFER - (UNIX_RECLEN + 8)
UNIX_RECLEN_P = UNIX_REC_P + RECLEN_TO_GO + 4
END DO
! Should be done - do some last checks
IF (BYTES_IN_BUFFER .NE. 0) THEN
IF ((BYTES_IN_BUFFER .NE. 1) .OR.
1 (LAST_BYTE .NE. 10)) GOTO 830
END IF
GOTO 900
810 WRITE (*,*) 'Error - too few bytes remaining in input file'
GOTO 900
820 WRITE (*,*) 'Error - start and end record lengths do not match'
GOTO 900
830 WRITE (*,*) 'Error - data remaining at end of file'
900 CONTINUE
! Close up
CLOSE (UNIT=2)
END
! USEROPEN routine to open file for memory mapping
INTEGER*4 FUNCTION UFO_OPEN (FAB)
IMPLICIT NONE
INCLUDE '($FABDEF)'
INCLUDE '($XABDEF)'
INCLUDE '($XABFHCDEF)'
RECORD /FABDEF/ FAB
INTEGER*4 CHANNEL, BYTES_IN_BUFFER
COMMON CHANNEL,BYTES_IN_BUFFER
STRUCTURE /XAB_STR/
UNION
MAP
RECORD /XABDEF/ XAB_HDR
END MAP
MAP
RECORD /XABFHCDEF/ XAB_FHC
END MAP
END UNION
END STRUCTURE
RECORD /XAB_STR/ OUR_XAB
POINTER (XAB_P, OUR_XAB)
! Set up for user file open
FAB.FAB$L_FOP = IBSET(FAB.FAB$L_FOP,FAB$V_UFO)
! Open the file
UFO_OPEN = SYS$OPEN (FAB)
IF (.NOT. UFO_OPEN) RETURN
CHANNEL = FAB.FAB$L_STV
! Find the XABFHC and calculate the number of bytes in the file
XAB_P = FAB.FAB$L_XAB
DO WHILE (OUR_XAB.XAB_HDR.XAB$B_COD .NE. XAB$C_FHC)
XAB_P = OUR_XAB.XAB_HDR.XAB$L_NXT
IF (XAB_P .EQ. 0) THEN
WRITE (*,*) 'Error - no XABFHC!'
STOP
END IF
END DO
BYTES_IN_BUFFER = ((OUR_XAB.XAB_FHC.XAB$L_EBK * 512) +
1 OUR_XAB.XAB_FHC.XAB$W_FFB) - 512
RETURN
END
! Routine to "switch ends" on a 4-byte integer value
SUBROUTINE SWAP_RECLEN(VALUE)
INTEGER*4 VALUE
VALUE = (ISHFT(VALUE, 24).AND.X'FF000000') .OR.
1 (ISHFT(VALUE, 8).AND.X'00FF0000') .OR.
2 (ISHFT(VALUE, -8).AND.X'0000FF00') .OR.
3 (ISHFT(VALUE,-24).AND.X'000000FF')
RETURN
END
record attributes.
about it.
C+
C
C ABSTRACT:
C
C
C
C
C
C
C AUTHOR(S):
C
C Steven B. Lionel
C
C CREATION DATE:
C
C
C DESIGN:
C
C
C
C
C ++---
C ++---
C [change_entry]
C-
IMPLICIT NONE
INCLUDE '($SECDEF)'
EXTERNAL UFO_OPEN
INTEGER STATUS
INTEGER*2 FLAGS
INTEGER*4 RETADR(2)
CLOSE (UNIT=1)
1 INADR,
1 RETADR,
1 %VAL(0), ! acmode
1 %VAL(0), ! gsdnam
1 %VAL(0), ! ident
1 %VAL(0), ! relpag
1 %VAL(0), ! pagcnt
1 %VAL(0), ! vbn
1 %VAL(0), ! prot
1 %VAL(4)) ! pfc
! Copy the file
FLAGS = 0
END DO
! Write last record
END DO
END IF
GOTO 900
GOTO 900
GOTO 900
900 CONTINUE
! Close up
CLOSE (UNIT=2)
END
IMPLICIT NONE
INCLUDE '($FABDEF)'
INCLUDE '($XABDEF)'
RECORD /FABDEF/ FAB
STRUCTURE /XAB_STR/
UNION
MAP
END MAP
MAP
END MAP
END UNION
END STRUCTURE
! Open the file
STOP
END IF
END DO
RETURN
END
INTEGER*4 VALUE
RETURN
END
Suggest a new solution for this problem
Post a New problem for GE BusSecure, 4-channel mobile
Email this problem
Email this problem
Can you Help with these TV Receivers and DVRs problems?
Celestial HD Digital Television...
I have just bought one of the... Answer This...
MITSUBISHI BLACK DIAMOND TV/DVD...
Hi, I am trying to tune the SKY... Answer This...
samsung HP-S4253 black screen,...
My samsung HP-S4253 42 in.... Answer This...
Repair Service
Find TV Receiver and. Repairman Near You:
Find Parts
