Question about Microsoft Xbox 360 Console
My xbox 360 drive will not open or close unless i use the emergency eject button yet it plays disks fine.
  • 23 Answers
That's a common problem with the DVD-Drives, this is going to fix it...
http://xbox-experts.com/e/tutorial.php?n=dvdopentray
I hope this helps.
Kind regards,
Wilhelm@Xboxexperts.com
Posted on Mar 08, 2009
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My xbox 360 arcade dvd drive is not getting power from the xbox 360 wont eject or close
Take it into a games store/ fixer man and get them to look at/ replace the motor that opens and closes the disk tray. =]
Nov 08, 2010 | Microsoft Xbox 360 Console
My xbox 360 cdrom won't keep
turn on your 360 and open the game drive. hold it open and turn of the 360. wait for it to power down completly. then turn the consel back on and it should close on its own now and stay closed as it should
Jan 07, 2010 | Video Game Consoles & Games
Hi there my 360 is having some problems,when i put a game in it keeps on telling me to insert the disk into an xbox 360, or if the auto run option is off,then it will just say play dvd or open tray? after...
after taking the entire drive apart i found that the laser / moter assembly was offset. this ment that the disk was tilted 1degree towards the laser and intern hittng the laser assembly that so many peopl think is "laser burn" which actualy is the disk physically hitting the laser. how u fix this is as easy as adjusting two screws were the moter and the laser/ tray assembly meat. now thses arnt nomal phillips, flat head or torx scews. i found that stickin a drill bit in the screw head annd turnin it with some pliers did the trick. this fixes the open tray error for good unless the disk is causing it. IF anyone gets open tray ocasionally this should stop it for good. also try cleaning inside of drive make sure connection to drive is good. try turning the system on then emmidiatly opening and closing the tray a couple time.
Jul 18, 2009 | Microsoft Xbox 360 Console
XBox 360 disc tray open
i have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Apr 28, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 elite dvd tray keeps opening and closing
Crack the case and open the dvd drive look for any debris that may be holding the tray from fully closing. Did you recently update the software to the new dashboard? Maybe there is a corrupt file. I would check the drive first. The likely hood is it is a simple problem just hard to diagnose with out haveing it in front of me. The other thing is this the real eject button is down on the metal box on the left under the corner of the DVD drive. check this there isn't something lodged against it or it may be broken. Pushing that button will wake the 360 and open the drive as you mentioned but why it would close on its own is a mystery unless there is a corrupt file or the eject switch is broken.
Mar 22, 2009 | Microsoft Xbox 360 Console
There is a problem with your disc tray. it depends on you if you want to send it in for repairs or just stick with it.
Might as well call xbox customer support to check the warranty status of your xbox 360.. Goodluck
Mar 08, 2009 | Microsoft Xbox Console
Xbox 360 draw fault
Try this, while the tray is closing press the eject button again. If that doesn't work you will need to replace the drive. buy the same model and move your logic board over to the replacement drive. It's paired with the xbox 360.
Dec 10, 2008 | Microsoft Xbox 360 Console
Sticking trays in dvd drive.
wat do i do? how do i open the drive
Sep 09, 2008 | Microsoft Xbox 360 Console
XBOX 360 STAYS OPEN / EJECTS GAME AFTER DOOR CLOSES,
sounds like a faulty sensor on the xbox rom drive,
if its still under warrenty, bring it back...
x-b-m
Mar 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
