SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
SOURCE: Whirlpool dryer MOD: GEW9868KQ2 wont heat. does
You have a bad thermal cut-off . This piece , is a small thermostat looking piece , located ( from the front ) farthest back , on the element housing ( containing the element ) , with 2 wires going to it . Pt # 279769 . This part also comes with the hi-limit thermostat , which should also be replaced .
SOURCE: Whirlpool dryer model LEB6300 series..
Hi Rylee
Thanks for using FixYa. If you have already checked all these things
including the thermostat & thermal cut off and it still won't start then
the issue is with the electronic control going bad and should be replaced. Please
accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
