Question about Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi 18" petrol chainsaw won't start
I have checked spark plug, OK. Have checked fuel and oil, all OK. Chain brake is not on. Saw has been stroed (clean) for about a month since last successful use.
  • 1 more comment
  • Anonymous Mar 18, 2009
    Saw won't start, spark plug works, new fuel ok, fuel line checked and ok, brake not on, less than a year old, less than 3 hours run time, even though spark plug sparks against the motor head when removed, there is no evidence of ignition when pulling to start, the switch is on. Help?
  • Anonymous Mar 22, 2009
    Exact same problem, saw is brand new never been started have primed fuel line and there is just no ignition?
  • Anonymous Apr 25, 2009
    I have model 10532 chain saw. Unit less than a year old. I started first time this Spring 2009. Ran for a few mins. but than stopped. Could not restart. Fuel leaks from right side when adding to tank.
    What should I do?
    Bernie G.
On my chain saw i checked my fuel lines and spark plug and they are good. i put new gas and oil in it. it will start but it will not stay running. what should i check next? thank you for your help
Posted on Nov 06, 2012
  • brettandmari
    brettandmari Dec 24, 2012
    sometimes fuel cystalise in carb if you donot use it for a long time
  • 42 Answers
My guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Posted on Mar 08, 2009
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
May 25, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain saw won't start
Things to check,drain and re fill with fresh fuel/oil mix, replace the fuel filter in the fuel tank, remove the spark plug, rest on top of the cylinder and check for a spark, if this is all ok remove the muffler and check the condition of the piston through the exhaust port, any signs of damage and the saw will have to come apart for further investigation.
May 30, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Craftsman chainsaw 18" 42cc doesn't start
Remove the spark plug and test for spark. If nothing, try a new plug set to 0.020" gap. If ok, put a small mount of fuel mix in the plug hole and try to start. If you get several pops, then check the fuel filter, air cleaner and muffler for plugging. Check the fuel lines for rot or damage. Make sure to use fresh fuel premix (40:1) using modern synthetic saw oil in it's own can and shake thoroughly just before filling each time. If you got no spark in the first test, expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and check for spark. If still nothing, replace the module using a thin business card for a gap gauge between the module poles and the flywheel magnets. If you did get spark, then investigate the ignition switch and wire for possible grounding. Hope some of this helps!
Jun 24, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Petrol leaking when turned up side down,Ryobi Chainsaw
Upside down is not a usual sawing position--only upright, or turned to the left or right side is recommended. If you need to undercut something, keep the saw upright and cut with top side of the chain/bar.This can lead to kick-back if the tip comes free of the log/branch, so you need to control the saw carefully. That's also why there is a chain brake on all newer saws. The leaking may be occurring where the fuel lines pass through the wall of the fuel tank. Hope this helps!
May 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
1,706 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
