Question about Gateway GT5056 PC Desktop
I have a Gateway Desktop that is 6 years old. I
I have a Gateway Desktop that is 6 years old. I need to remove the hard disc before I dispose of it. Please tell me where to start.
    Scholar:
  • 82 Answers
This procedure depends a lot on the exact configuration of your Gateway. They are good at making proprietary towers that are different from all others. Unplug all cords from the back of the computer. remove screws along the back on the side of the tower. ( Most of the time it is the right hand side if you are facing the back of the tower :) ) Pull back on the side panel. If it slides back then you're in!! Inside there should be two light or dark grey cables that are flat and about 2 inches wide. one will go up to the top of the tower to the cd player. the other will go down lower to a 1 inch thick rectangular device that is your hard drive. If you are trying to save your hd for use, then be careful at this point. If you are not then just tear away!! Remove the grey (IDE) cable from the back of the hd. Then remove the 1 inch wide white power cable connector that is now exposed on the other side of the ide cable. Good. Now here is where it can be very different depending on your model. The hd will either be screwed directly to the chassis on both sides, or it will be encased in a plastic sled device that will have a latch and will slide out. If it is in the sled, then locate the tab, push in, and pull back. Voila! HD is out. If it is screwed directly into the chassis, then you will need to take off the other side cover of the tower in order to access the screws on the other side of the HD. Then remove. If you are going to store for reuse, it is best to store in a static free bag, otherwise, dispose of according to local regulations for e-waste.
Posted on Mar 08, 2009
  • Kevin Hughes Mar 08, 2009
    You can wipe the hd by using an electromagnet, or remove the circuit board on the bottom with a screwdriver and dispose of seperatly....
Want to re-install everything on gateway desktop
Hi.
The system disk is the hard drive, use the recovery disks to reinstall the operating system.
Regards.
Dec 30, 2012 | Gateway Computers & Internet
I've got an old Gateway desktop I need to connect to a wireless router for my job. I just bought a new, much stronger NetGear router and it still won't connect. I no longer have a laptop and I'm DESPERATE...
Unless you've installed a wireless card in your old desktop you will never connect wirelessly.
Desktops don't come equiped to do wireless communications. And an "old Gateway" surely does not have those capabilities.
You have 2 options
1) Purchase and install a wireless card for your Gateway
2) Use it hard wired... Purchase an "Ethernet cable" of sufficient length and plug it into one of the open ports on the back of the router and into the only place it will fit on the back of your computer
Jan 31, 2011 | Gateway Computers & Internet
I want to change hard disc, need instruction how to replace the old disc and install new one
There should be a removeable panel on the bottom side of the laptop that covers the hard drive. there might be several, so you may have to remove several panels before you find the hard drive.
To remove the hard drive, slide it away from the connector side to unhook it, then lift it up and out of the compartment. Examine the connector side of the hard drive, because there is probably an adapter affixed to the connector/contact. remove the adapter (if applicable) and put it on the new hard drive, then drop it down into the compartent and slide the new hard drive in towards the connection to connect it.
Now, you will need the windows disk that came with the computer to reinstall windows. if you do not have a disk, you can order one from sony.
if, instead of starting with a fresh windows install, you wish to copy windows with all of your data to the new hard drive, you will have to hook up both the old and new hard drive up inside a desktop and use cloning software such as Archaos makes to copy the old disk's data onto the new one, windows and all. These hard drives may be smaller than standared hard drives, but once the adapter is removed, they have the exact same SATA connectiuons as do standard desktop[ hard drives and will hook up to a SATA capable desktop (any made within the last 5 years) just fine.
Nov 30, 2010 | Sony VAIO VGN-SZ220/B Notebook
My gateway T5674 desktop PC needs to a new hard drive replaced, where is it located and is it done? the original hard drive was removed.
Take The Side off and look for a silver & Black Box it should be near the front of the Computer under the disc burners
Oct 17, 2010 | Gateway GT5674 Desktop PC
Hard drive crash after 1 year
if u have new harddrive then simply first remove crash harddrive from computer .
Then if u have sat harddisk connect it with sat cable .
I fu have ide harddisk tehn connect with ide data cable. simply.
May 04, 2009 | Gateway GT5220 PC Desktop
I have a Gateway computer that is 10 years old. I
1- you have to change your power supply and you have to change your hard drive to one biger than you have but it must be IDE.
Apr 06, 2009 | Gateway 310S (2900621) PC Desktop
Want to remove my hard drive before I recycle my computer
Open the two sides . Remove the wiring frm the hard driver. Remove the hard drive from the cage.
Apr 04, 2009 | Gateway GT5220 PC Desktop
Computer is three years old i want to replace the hard drive i have all disc is this a simple task?should i just wipe the old one?
simple , but you would have to buy an EIDE drive and not SATA that is in today's market.
You don't have to wipe the other, you can use it for backup or to save you files on.
To install it, just follow the manual, it is not difficult.
Mar 30, 2009 | Gateway Essential 400 PC Desktop
Hard drive for Tower PC
Hi I have a gateway tower about 7-9 years old. could you tell me how much a 60- 80 gig harddrive will cost and where I could get such an animal? I need to run a couple of programs and I don't have enough room.
Sep 09, 2008 | Gateway GT4022 PC Desktop
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Gateway GT5056 PC Desktop Logo
99 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
