Question about SkyScan 86742 Digital Atomic Wall Clock
Skyscan atomic clock receives time signal but is displaying GMT rather than EST.. how do I get it to display EST?
  • 5,568 Answers
You didn't tell us the model number but whatever it is, you should find instructions here:
Skyscan website
Our various 'atomic' clocks have either a menu that lets one select or a simple slide switch with US time zones from which to choose.
Posted on Mar 08, 2009
Manuel for 88900
Are you getting a signal? The disp Ay should show that it is picking up radio time signal on the display. If not, reposition to a totally different location. If still no signal, receiver must be off. May be warranty issue.
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
Manual for SkyScan atomic clock -model 86742 I need to know how to change the clock to eastern time.
Hello
The SkyScan ATOMIC Clock
With the Skyscan Atomic Clock, you have the most accurate timepiece within the continent. It can receive the time signal transmitted by the National Institute of Standards and Technology (NIST), which is regulated by 3 atomic clocks and deviates less than 1 second within 3,000 years. The NIST broadcasts the time signal (WWVB, 60kHz) continuously from Fort Collins, Colorado. This signal can be received anywhere in the continental USA that long wave (AM) radio reception is possible with a portable radio. It is expected that the signal can cover a distance of over 2,000 miles from the transmitter. Therefore, your clock will receive the signal within the broadcast range anywhere an AM signal can be received; generally the signal cannot be picked up in massive metal and concrete structures unless near a window. In addition, some environmental effects (see next page) may affect the transmitting distance.
Nov 08, 2011 | SkyScan 86742 Digital Atomic Wall Clock
Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at skyscaninfo.com
Apr 04, 2010 | SkyScan 86709 Atomic Wall Clock
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 15, 2010 | SkyScan 86742 Digital Atomic Wall Clock
I am getting EST time. I live in MST. How do I reset the time ?
Successful reception of the time-synchronization radio2_bing.gif signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 02, 2010 | SkyScan 86709 Atomic Wall Clock
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
Set the time on my skyscan atomic clock mo 8672
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 13, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Cannot reset my SkyScan Atomic clock after changing batteries
Online manual is at link http://skyscan.info/content/manuals/25-model-87315.html
Dec 29, 2008 | SkyScan 86709 Atomic Wall Clock
S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Dec 12, 2008 | SkyScan 86709 Atomic Wall Clock
I have a87900 model skyscan,can;t get it reset after replacing batteries
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
Dec 17, 2007 | SkyScan 86742 Digital Atomic Wall Clock
SkyScan 86742 Digital Atomic Wall Clock Logo
739 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
